Old 09-03-2014, 01:02 PM   #1
Salkin's Avatar
Default Do I need this?
I've ordered a standard setup station for my 1/10 TC.
Do I also need this?:
http://www.hudy.net/xhudy/products/p...5&kategoria=64
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 09-03-2014, 01:23 PM   #2
samnelso's Avatar
Need? nah.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 09-03-2014, 09:58 PM   #3
Clawhammers's Avatar
What standard setup station did you buy ?
I purchased Complete Set of Set-up Tools + Carrying Bag - For 1/10 Touring Cars several months ago, and it already contained the tweak setup.
Clawhammers is offline   Reply With Quote
Old 09-03-2014, 10:38 PM   #4
Salkin's Avatar
I purchased this:
http://www.hudy.net/xhudy/products/p...1&kategoria=64
And the 1/10 tc setup board.
Was just wondering if anybody uses the tweak tool also?
Old 09-04-2014, 05:03 AM   #5
Regional Moderator
CarbonJoe's Avatar
I purchased this:
That bubble level tweak station is usually used on pan cars. The one in that Complete kit above is for TCs.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-04-2014, 06:51 AM   #6
The complete TC kit now comes with the bubbles style too, they changed it recently. They didn't drop the price though! Note the disclaimer down the bottom of that link.
The cars these days are so much better balanced with lipos than they were with NiMH batteries, so you find that tweak due to L/R balance is minimal. When I rebuild my car, I always check it, but with my current electronics and using std battery offset (Salkin, you can adjust it on the 418 by adding/subtracting spacers to the lipo stopper) it's always perfect.
So to answer, "need" - hmm, nah. Not really. You can achieve 90%+ what the tweak station does with the $10 balance pins.
cplus is offline   Reply With Quote
Old 09-04-2014, 06:53 AM   #7
If you're going to spend more stuff on HUDY gear, get the thumb screws for the triangles and axels. They are a must.
Old 09-04-2014, 12:31 PM   #8
Shame if you have already ordered it as there are so many other brands just as nice , as hudy just means extra
And no that only show tweek on the car and if you not going for 1st place in all the nationals it's point less and having spring collars adjusted badly on the car give u tweek readings and confuse you
As for weight use scales but only when you start needing to find .05 of a lap not when ur hunting seconds a lap
Just get a setup station and regualy de tweek the car on a flat surface and track it up
tcboy1983 is offline   Reply With Quote
