Tamiya 1/10 On-Road - What is the difference? >
Old 09-13-2005, 12:57 PM
  #46
PD2
PD2's Avatar
Here are the part numbers and parts I found that I think are the servo mounts/posts/stays:
53478 Aluminum Racing Steering set
53594 RC TA04 Aluminum Steering Post (Fluorine Coated)
53596 RC Aluminum Servo Stays (Short)
Of these, which one is correct and if not any of these, which one would be correct for the TA04?
Thanks!
PD2
PD2 is offline
Old 09-13-2005, 04:38 PM
  #47
I believe that is what you are looking for. Let other ppl on the forum confirm.
rcnewb2004 is offline
Old 09-14-2005, 01:06 AM
  #48
Originally Posted by PD2
My biggest issue is getting an older version car and not having the parts support that I need.
Man there is no risk on not finding parts for Tamiya.
On RainbowTen you can always ask any Tamiya part (even if not listed on stock) and they will just charge you 20% more then the list price.
Tamiya is supposed to keep the basic spare parts for long long time.
e_lm_70
P.S: BTW since TA04/TB02/TA05 cost all almost the same ... I will take the latest ... since it is little bit better designed !
The TA05 with a CF chassis will be a killer ... but if you calculate all the money for all the hop-ups ... it will be more expensive then a 415MS or EVO IV ...
e_lm_70 is offline
Old 09-14-2005, 03:00 AM
  #49
PD2
PD2's Avatar
I had another person tell me that these woud work:
http://www.speedtechrc.com/store/ebp...id=266&id=4867
I assume that the design of the post did not change much going from a TA-04 to TRF 415, right?
Thanks for the help!
PD2
PD2 is offline
Old 09-15-2005, 03:50 AM
  #50
PD2
PD2's Avatar
Actually, I found what I was looking for - ended up going out to Tamiya and downloaded the manual for the TA-04S. Got the part number and come to find out Tower Hobbies has them in stock - grant it, you have to purchase the tree of parts, but it's like less than $9!
Needless to say I'm now the owner of a TA-04 that is coming with a carbon fiber chassis, tuned shocks, and about 3 different bodies.
After doing a search on the forum here, it appears that several people tried to start threads on the TA-04 and TA-04R - which forum/thread is better to read to obtain further info on the chassis?
Thanks again for all of your help guys! I really appreciate it!
PD2
PD2 is offline
Old 09-15-2005, 11:58 AM
  #51
loopedeloop's Avatar
Try searching for trf 414 that will most likey be the best thread about the TA04.
loopedeloop is offline
Old 09-15-2005, 12:19 PM
  #52
PD2
PD2's Avatar
SWEET! Thanks! I'll check it out!
PD2
PD2 is offline
