Old 09-07-2005, 12:26 PM   #1
kerry's Avatar
Default ZAPPING MAGNETS TO INCREASE TIMING
as the title suggests, i am interested in how to zapp a stock motors magnets to increase timing, what are the pros and cons of doing this and does it really work. any input would be appreciated if you have tried this what have been your results.
all the best
kerry is offline   Reply With Quote
Old 09-07-2005, 12:29 PM   #2
Mal
Registered User
Cons is that it's boarderline cheating. It's against roar rules.
Mal is offline   Reply With Quote
Old 09-07-2005, 12:30 PM   #3
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Not a good idea as your motor will tend to fade during a race and you will lose the magnetic balance between the armature and the magnets. Basically you will over saturate your magnetic field which will cause heat. Dyno results will look really good but track testing is where its at and it simply doesnt work. Murphys Law.
dgullickson is offline   Reply With Quote
Old 09-07-2005, 12:31 PM   #4
Some tend to argue its against Roar Rules but it simply is not against the rules.
Old 09-07-2005, 01:01 PM   #5
Doug D's Avatar
Trader Rating: 54 (100%+)
FYI - Timing advancement by zapping IS illegal according to ROAR and will be checked at the on-road Nats. Apparently a Yokomo Tesla Meter will be used for this test. If your willing to do this, why not just run Modified?
Doug D is offline   Reply With Quote
Old 09-07-2005, 03:12 PM   #6
EddieO's Avatar
R/C Tech Charter Subscriber
It doesn't work....and simply isn't worth it. It however is NOT against the rules, but some down in Florida seem to think it is, so they will be testing for at the Nats....
Please show me where in the rules it says you can't do it.....last I checked, it specifically ALLOWS the zapping of magnets and gives no direction on what is or is not allowed in the process.....if ROAR wants to make it illegal, then the rules need to specifically say it....however, its going to be a nightmare to tech and rule correctly, as people could accidently zap stuff like that and the armature can actually simulate the symptoms when it over saturates a normally charged magnet.....sorry, but the people teching this understand little how the whole armature to magnet relationship works. My guess.....people who honestly did not do it will end up disqualified....
And No....team br00d doesn't do it, never have....we just find it funny to lap the idiots who think it works.......
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 09-07-2005, 03:23 PM   #7
It doesnt state anywhere you cant Zap your magnets and in which way form or fashion. Give me the section number you are referring to.
Old 09-07-2005, 03:27 PM   #8
Well said Eddie. Like Eddie said the guy teching barely knows how to tech the motor for the correct armature in the can, how the hell would he know how to tech the magnetic field?
Old 09-07-2005, 04:29 PM   #9
Mal
Registered User
I thought the rules say that you can't advance the timing of stock motors? Don't you advance the timing by zapping the magnets off center?
Old 09-07-2005, 05:30 PM   #10
EddieO's Avatar
It tricks the motor into thinking it has more timing....it does not actually increase the timing. It's no different than the arms in the motor, which are designed and approved to do the same thing....or timed brushes....
Timing in simple terms changes on the endbell and the comm placement, which BOTH are defined in the rule book.
if they are gonna outlaw zapping the magnets, then they need to require full blank arms and no timed brushes....
Later EddieO
www.teambrood.com
Old 09-07-2005, 05:33 PM   #11
imprsme's Avatar
Trader Rating: 74 (99%+)
Also when you cut the com. doesn't that affect the timing?
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 09-07-2005, 08:10 PM   #12
Zapping motors..... Zapping batteries..... Where's it all going to end?
Stock is simply that.. stock!! Nuff said!!!!!!!!!!
John Warner is offline   Reply With Quote
Old 09-07-2005, 08:15 PM   #13
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I just started zapping my tires. Works better than sauce!
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 09-07-2005, 08:28 PM   #14
SpeedDesignz's Avatar
Send a message via AIM to SpeedDesignz
Now zapping is basically the same as timing the motor,
would'nt using a brush timing jig do the same thing. Only a whole lot cheaper. Those Zapper's are kinda $$ big bucks $$ right ?
Kinda seems like a disadvantage to the regular racer that can't afford that $700 zapper.
NYC Hobbies / Eurotek motorsports / SpeedDesignz / BackBreaker Racing !!
SpeedDesignz is offline   Reply With Quote
Old 09-07-2005, 08:49 PM   #15
Yeah.... I zapped my shocks last week, and man o' man what a difference!! That baby handles like it's electrifiyed...
Difference b/tween ESC timing and timing on motor? Loverc Electric On-Road 8 04-11-2008 05:45 PM
POST INCREASE! squad car Rookie Zone 490 11-23-2007 10:47 AM
whats the difference between quad magnets and 2 magnets? 03phillipsr Electric Off-Road 7 04-11-2007 04:20 PM
Zapping Magnets gcooper Electric On-Road 29 01-22-2004 01:23 PM
Zapping Magnets?? Gravity Electric On-Road 4 12-14-2001 12:58 AM
