TAMIYA TRF 101W
Old 08-26-2014, 06:44 PM
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Default TAMIYA TRF 101W
Just got the new kit and lookin to start some... discussion.
Gonna be trying to set it up for carpet with no tire doping allowed but will be practicing with no sauce on carpet where sauce is allowed.
Gonna be interesting to start.
Ideas?
'cuda
F N CUDA is offline
Old 08-26-2014, 06:46 PM
RedBullFiXX's Avatar
Check here Cuda dude
http://www.rctech.net/forum/electric...hlight=trf+101
RedBullFiXX is offline
Old 08-26-2014, 06:58 PM
Ph3nyx's Avatar
with foam or rubber ?
Ph3nyx is offline
Old 08-26-2014, 06:59 PM
robk's Avatar
Trader Rating: 22 (100%+)
Buy a gyro!!!!
robk is offline
Old 08-26-2014, 07:33 PM
F N CUDA's Avatar
Originally Posted by RedBullFiXX View Post
Been thumbing thru it
Some differences yet many similarities
You recommend battery (shorty) front or rear?
Links center, inside, outside or any combo of?
Japan is running foam
Originally Posted by robk View Post
Buy a gyro!!!!
Yep gotta get schooled on those things fast!
F N CUDA is offline
Old 08-26-2014, 07:52 PM
EDWARD2003's Avatar
I spoke with this old Japanese guy, Masami I think... He said gyros are good but make the car push too much.
Japan is running foam only. I haven't seen rubber tires over here.
EDWARD2003 is offline
Old 08-27-2014, 09:37 AM
R/C Tech Elite Member
JayL's Avatar
so the front is 200mm only, right?
JayL is offline
Old 08-27-2014, 10:13 AM
F N CUDA's Avatar
Correct
Fat rear tires is the difference in the rear
I don't believe the axle width is different
F N CUDA is offline
Old 08-27-2014, 11:54 AM
Vyger's Avatar
Cuda, find out what type of battery you're running, LiFE, NiCad, size, etc. Tamiya only allows certain types for their Worlds event. You should talk to Sean Wu, Bensi, Solomon, Rod, all of those guys to see what they used and how they conditioned them ahead of time. Just my 2 cents.
Vyger is offline
Old 08-27-2014, 01:16 PM
F N CUDA's Avatar
For sure need specs ASAP
F N CUDA is offline
Old 08-27-2014, 06:24 PM
I think last year it was
Life battery, handout
Spec motor handout, some sort of buchi
Kit foam tires handout, full size, no sauce, which remained in tech
Fred should have the dialed setup for you
Old 08-27-2014, 06:32 PM
F N CUDA's Avatar
Handout is good, no buy
Now the secret is battery conditioning from what I hear.
New car manual photo shows 103 type foamies, little rims big sidewall fatties for rear and 104 type foamies front, big rims smaller sidewall and another switch is along with the 200mm width it's F104 wheelbase.
Long and wide.
Sounds fast (with correct horsepower of course).
F N CUDA is offline
Old 08-27-2014, 07:59 PM
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 39 (100%+)
I've got a trf101w for sale.
box is opened, chassis is prepped with CA. Otherwise, unbuilt with everything in the bags unopened.
$350 shipped to the US of A
lagcisco is offline
