Xray FK05 USGT lipo set up help >
Old 08-22-2014, 09:07 PM
MartyD.'s Avatar
Default Xray FK05 USGT lipo set up help
Hello,
Let start out by saying I am new to onroad, I picked up a couple of older cars for VTA and USGT. Want to run the FK05 in USGT and want to know what would be the best method with securing the Lipo battery. I have seen a few Lipo Battery arms for T3s and T4s. Im wondering if any one knows if this will work on the FK05 chassis. Any help with this would be appreciated.
MartyD. is offline
Old 08-22-2014, 09:10 PM
mkiiina's Avatar
Trader Rating: 71 (100%+)
There is a lipo "conversion" from xray. I'll see if I can find the part number as I have one on my T1 as well. You need to be careful about the battery height as the front belt will rub if its too tall.
mkiiina is offline
Old 08-22-2014, 09:51 PM
MartyD.'s Avatar
Thank you, I have been searching online for info on running a lipo on this chassis, not much out there. Seems like its a real pain to run one without issues. Would I be better off getting a lipo ready chassis to race? This is a beautiful car, with a ton of new and used parts.... Would really like to use it with out hacking it up.
MartyD. is offline
Old 08-22-2014, 10:46 PM
alcyon's Avatar
Some lipos are lower than others. A standard lipo is 25mm high. Orca now has a low cost 6000mah lipo that is 23mm high and only weighs 270g compared to other 6000mah usually 300g.
alcyon is offline
Old 08-23-2014, 12:46 AM
Brokin Racing's Avatar
Trader Rating: 74 (100%+)
Originally Posted by MartyD. View Post
Hello,
To my knowledge there wasn't an option part from Xray to fit lipo's to the FK05
If you can secure a "Bitty" lipo tray, common some years ago, that would be your easiest & most effective option (re chassis balance) or make up a couple of light alloy brackets yourself... & no the T3 T4 items will not fit
You could also get BezerkRC.com to make you a new "lipo suitable" lower deck
Brokin Racing is offline
Old 08-23-2014, 04:07 PM
mkiiina's Avatar
Here is the part I have:
http://www.teamxray.com/teamxray/pro...ing%20Brackets
I think stormer had the first one and then I got a second one from a shop in canada. I did space them up some.
HTH.
mkiiina is offline
Old 08-23-2014, 04:32 PM
MartyD.'s Avatar
HTH.
Thanks for the help, this car I equipped with the graphite battery strap. Ive wondered if I use Velcro on the chassis and battery, spaced it away from the belt if that would eliminate side to side movement. My concern is making the COG high?
MartyD. is offline
