Old 09-05-2005, 03:25 PM   #1
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Default How hot are my batteries suppose to get?
Hi I charge my batteries at 5a/6a and I have 2 3700 GP zapped from japan. The ending temp is over 51 degrees c. I think this is tooo hot/ I put the delta peak v drop to .04 v?
Sushi Man is offline   Reply With Quote
Old 09-05-2005, 03:41 PM   #2
wolfman76's Avatar
Try .03 or even 0 delta peak if your charger has this function.
wolfman76 is offline   Reply With Quote
Old 09-05-2005, 03:54 PM   #3
wolfman76's Avatar
I think the higher the number e.g. .04 .05 .06 etc etc the hotter the cells will get. If i'm wrong some one please correct me on this. But what i have been told Nimh batteries don't like high Delta peak. I use .03 for cooler weather and zero delta peak for warmer weather. I also Equalise my cells on a Much More V-zero tray before i charge them.
Old 09-05-2005, 06:14 PM   #4
hpipro321's Avatar
when i use my advantage charger mine get only 40 degrees c
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 09-05-2005, 06:20 PM   #5
nordheim's Avatar
charge at a lower amp setting. I charge mine around 4a and don't see the temperatures go too high.
nordheim is offline   Reply With Quote
Old 09-05-2005, 06:28 PM   #6
When charging my GP 3700's I have the delt peak set .03 and use a temp gun to determine when they are done charging. 125 - 130 degrees.
knapster is offline   Reply With Quote
Old 09-05-2005, 08:35 PM   #7
sushi, was is the conversion from 41c to what like 130 or 140 F. if so should be around 125 or 130. come see me at the track next time your there, ( i sold you the tray)
Turtlemaster is offline   Reply With Quote
Old 09-05-2005, 08:55 PM   #8
Jeff Brown's Avatar
41C = 105F
Well, that would work but I doubt the cells are fully charged. Unless you are indoors in a cool room and such.
I would keep most cells in the range of 120 to 135F. I charge my 3300's at 6amps with a .12mv cut off and they peak at about 125F in the Florida Shade. Which is still HOT!
Just takes some testing to get the settings for your area.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 09-05-2005, 09:39 PM   #9
Sushi Man's Avatar
125f is how much in c?
Old 09-05-2005, 09:52 PM   #10
Jeff Brown's Avatar
52C
http://www.wbuf.noaa.gov/tempfc.htm
Jeff
Old 09-05-2005, 09:55 PM   #11
josh69162's Avatar
Send a message via AIM to josh69162
F = C * (9/5) + 32
So...
C = (5/9)(F-32)
125 deg. F. would be 51ish degrees Celcius. 50 isn't really all that bad. Its about 124. That's actually a little on the cool side. Most people like their batteries to peak between 130 and 140. So you're on the safe side. I wouldn't be worried.
-Josh
josh69162 is offline   Reply With Quote
Old 09-05-2005, 10:41 PM   #12
sorry, just have to correct you on deg C conversion:
C=5*(def F - 32)/9
Noel_E is offline   Reply With Quote
Old 09-05-2005, 10:45 PM   #13
josh69162's Avatar
Well, they both work out the same way. There's multiple ways to write the conversion.
-Josh
EDIT: I stand corrected. I changed my conversion...
Old 09-05-2005, 10:55 PM   #14
Send a message via ICQ to Louis Send a message via MSN to Louis
Which charger are U using??
Louis is offline   Reply With Quote
Old 09-05-2005, 10:57 PM   #15
Sushi Man's Avatar
Well its a old charger, but I bought it new. A Orion D-67
FT GT2 RTR, Ofna starter box w/ batteries, Dynamite Vision Peak w/ batteries phayes526 R/C Items: For Sale/Trade 8 07-15-2008 12:35 PM
COLT 10, INTELLECT matched batteries, 1/8 shell, receiver batteries and blinged 350Z blueGiga Australia For Sale/Trade 3 06-16-2008 07:59 PM
Fs 2 7cell mini t intellect 1200 batteries, blind batteries t to the maxx2 R/C Items: For Sale/Trade 0 03-05-2006 04:33 PM
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
Which way are comm suppose to spin when cutting? Super Steve Electric On-Road 8 07-09-2004 05:34 PM
