Like Tree41Likes
Tamiya FF04
Old 11-18-2019, 10:53 AM
  #256
At this point, with the release of the pill based tamiya mounts.. who cares?
Nerobro is offline
Old 11-18-2019, 11:51 AM
  #257
True. I like that you don't have to buy a ton of mounts. Unfortunately the FF04 does not accept the new style split mounts unless you drill out the deck for it.
V8 Rumble is offline
Old 11-18-2019, 12:17 PM
  #258
https://www.tamiyausa.com/shop/optio...ble-sus-mount/ This looks like it'll fit just fine, at both ends.
I'm not entirely sold on a lot of the suspension setups. But I've done almost all of my racing on carpet, which leans heavily on the stiffest setup you can get. Asphalt, and other surfaces where you need to fight for all the traction you can find... split mounts would be the thing?
Nerobro is offline
Old 11-18-2019, 12:23 PM
  #259
Those would work for sure on either end.
Old 11-18-2019, 01:19 PM
  #260
1/8 IC Fan's Avatar
Trader Rating: 97 (100%+)
Also dont forget Exotek may have some mpunts should you not find all you need.
1/8 IC Fan is offline
Old 12-01-2019, 08:10 PM
  #261
1/8 IC Fan's Avatar
So took the sons front apart for service... anyone else getting play in their front arm mounts. Running 2e. 1A in front and ton of fore and aft play / side to side. Arm holes are all good. Thought it was them but its not. No issues in rear running 1XD & 1A...
(I know the Orca is m/a screw)
Old 12-01-2019, 08:35 PM
  #262
JoeyE's Avatar
Trader Rating: 44 (100%+)
Are you using plastic mm shims or aluminum? Plastics will wear down and create slop. Also lay your mount flat hole facing down on glass to see if it is straight. These bend easy
JoeyE is offline
Old 12-01-2019, 09:59 PM
  #263
1/8 IC Fan's Avatar
Mounts are good, and all Aluminum shims, with only .3mm play so as not to bind. Shafts were ll brand new, not bent or too short. For the time, I used super glue in all the 1A mounts to take up the play (like we did in the Pro10 days on ball cups). Ordered up new mounts and balls. Everything else is straight. Just weird it is on the front end only....
Old 12-01-2019, 10:35 PM
  #264
MikeR's Avatar
Trader Rating: 15 (100%+)
Use thin metal .1mm shims for the fore/aft play (slightly loose is better than slightly tight). This will in turn balance the inserts in the center of the blocks and removes the side to side play. Pretty standard operating procedure for the ball insert suspension blocks yet stays remarkably free swinging. Always remember: a little suspension play = more traction.
MikeR is offline
Old 12-02-2019, 08:34 AM
  #265
1/8 IC Fan's Avatar
Thanks Mike, we got it sorted for now, I checked my TB06 as well, yets its 1A's are still good. On the Ff04 we still have some play, but not as much as a Walmart R/C anymore, and the arms fall freely. We will hopefully get through the indoor season, until new ones arrive, and order up some Exotek ones too, for good measure
MikeR likes this.
Old 12-02-2019, 09:42 AM
  #266
sosidge's Avatar
Are those actually Tamiya mounts? Because I don't recall that style of thin italic marking being used by Tamiya in the past.
sosidge is offline
Old 12-02-2019, 12:21 PM
  #267
1/8 IC Fan's Avatar
Great point... i did not even think of that. They are also cut different than the ones on the Evo, hmmm. Good catch Sosidge. Well Genuine Tamiya ones are on the way. Thanks again everyone for the input.
EDIT: Did some digging, my.son had gotten these through eBay. The listing showed the OP Tamiya PN, but turns out they are 3racing ones not OEM....
Old 12-04-2019, 05:37 AM
  #268
Hoyle33's Avatar
If anyone has a FF-03 or FF-04 for sale, I am looking for a slider/roller.
PM me!
Hoyle33 is offline
Old 12-05-2019, 03:58 PM
  #269
Mine is complete. Will use it in usgt and maybe tcs if I can. Was looking at the exotek black suspension mounts to keep the black theme but they don't have to many mount options.
Old 12-06-2019, 07:28 PM
  #270
Nicadrauspro4's Avatar
Nice and clean.
Tamiya should have at least made black suspension blocks to complete this kit. Makes me really wonder why they included the plastic ones on this kit while they've included aluminum in the FF-03R and FF-03Evo.
Nicadrauspro4 is offline
