Team powers xbooster cap >
Old 08-19-2014, 08:02 PM
bornox's Avatar
Trader Rating: 29 (100%+)
Default Team powers xbooster cap
does anyone knows here if the team powers xbooster legal? thanks!
bornox is offline
Old 08-19-2014, 09:08 PM
xrayaustin's Avatar
Trader Rating: 12 (93%+)
It is
xrayaustin is offline
Old 08-20-2014, 06:32 AM
bornox's Avatar
Originally Posted by xrayaustin View Post
It is
Cool! Thanks!
bornox is offline
Old 08-20-2014, 04:35 PM
I think these may just be a con.
Effectively , the most amps will be drawn from whatever has the least total resistance, that would allways be the batt.
It is in effect working like a tiny tiny batt in parallel with the main batt : ie snake oil.
It wont magiclly turn on for a boost when needed
1101 is offline
Old 08-20-2014, 04:45 PM
Is that stated somewhere? I thought it was caps in a metal container. Never even thought it would add boost to anything.
HawaiiBob is offline
Old 08-20-2014, 07:41 PM
bornox's Avatar
i got it for free. so, i guess there is no harm on trying it. lol
bornox is offline
Old 08-20-2014, 07:54 PM
nf_ekt's Avatar
Trader Rating: 115 (100%+)
Packaging and presentation is everything, no? Mo-powah? Who knows.. at least one guy (former roar champ) I talked to said he noticed nothing significantly different regarding performance. It does look cool though . If there is a difference to a regular old cap as we have always known, I'm curious to what it is.
nf_ekt is offline
Old 08-20-2014, 08:29 PM
Just a cap in a box.
Key is to mount it as close as possible to the ESC but I doubt it will do much.
frozenpod is offline
Old 08-21-2014, 09:35 AM
erchn's Avatar
I believe the xbooster doesn't provide the filtering that the normal capacitors provide, so the recommendation is to run both. I cannot speak to it's effectiveness though.
erchn is offline
Old 08-21-2014, 10:03 AM
I have tested the Xbooster with and without in 17.5 and 13.5 and there is a difference in punch when you run it. Also seems to make the car not fade as quickly.
And yes the Xbooster is not used for signal filtering, you MUST leave the original cap.
James321 is offline
