Old 08-14-2014, 02:01 AM   #16
tc3team's Avatar
there is no difference apart from the safety of deans plugs, unless you are very bad at soldering.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-14-2014, 05:19 AM   #17
Deans are marginally (you will never tell on the track) better compared with 4mm bullets. I now use 5mm bullets.
frozenpod is offline   Reply With Quote
Old 08-14-2014, 05:52 AM   #18
Skiddins's Avatar
Though SMC have tested 5mm connectors and they were always slightly higher resistance.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 08-14-2014, 06:10 AM   #19
Skiddins's Avatar
Originally Posted by Airwave View Post
That's probably because Jiles is sponsored by Team Orion and that there is a superstition about the fact that there is less current less with the wires going out from the case instead of the tube welded inside the case... ^^
Not superstition though
The problem with packs that use Deans is that the balance cable will also stick out and they end up with the case slowly cutting into the balance leads.
This is exactly why I stopped using Deans Thunder Power packs
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-14-2014, 06:14 AM   #20
howardcano's Avatar
Trader Rating: 35 (100%+)
I'm curious: the thread title mentions "Deans Fake". Are there indeed copies of Deans connectors being made? I haven't seen any myself.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 08-14-2014, 06:17 AM   #21
howardcano's Avatar
I've been using Shoe Goo to add some strain relief to this area, with good results.
Howard Cano
Old 08-14-2014, 06:28 AM   #22
Suspended
Yes howard their are knock off deans in the xt and standard deans...
the knock off deans are slightly off color.. a lighter red and a looser fit to a standard deans .. when i run into people with these I always recommend heating plug end with lighter and using needle nose to tighten opening(make it smaller) also they tend to melt under 45 amp draw.. deans about 60 amp
and the deans xt I like these best I will always use these at 80 amps no melting and I just like them more for my uses..
Raising hand cause I have never crossed a bullet plug cuz i will never use these due to that reason and there is no advantage to using them in amps ir resistance..
just ask .I may know the ANSWER !
ElectricMann is offline   Reply With Quote
Old 08-14-2014, 08:10 AM   #23
The knockoff deans really are no good. Unless your highly skilled at soldering the plastic always melts and leaves the plugs hard to line up. I've never had this issue with real deans. So if your a pro at soldering and running low power setups the knockoffs may work OK for you.
2uzferunner03 is offline   Reply With Quote
Old 08-14-2014, 09:20 AM   #24
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I used deans for a long long time . real and fake but only in vta or 17.5 tc. And typically kept my cheap connectors on my charger or discharger ... now that its lipo im using bullet 5mm and even tho one yr ago i did hook one pack up backwards i still use them . U have to be careful. The orca packs can be flipped over allowing you to reverse the wires...... (i was late for my Amain...)
but in tc i prefer to use bullet connectors to keep any flimzy wires as low as possible without adding any extra weight high in the car..
but if connectors are a must i loved the EC3 . Flow more current than deans (dont come unsoldered in pro4 SC ) less risk of shorting out from wires not being exposed (if shrink wrap gets damaged) and no need for shrink wrap and the EC3/5 is way easier to solder
jlfx car audio is offline   Reply With Quote
Old 08-14-2014, 10:44 AM   #25
locked's Avatar
Originally Posted by grippgoat View Post
Raise your hand if you use bullet plugs and can honestly say that you have never connected the wires backwards.
<puts hands firmly in pockets>
-Mike
Never and all of my cars use bullet connectors. You just have to glance at it for half a second before plugging it in. I don't understand how so many people make this mistake. It takes no effort to get it right and you know if you do it wrong, you'll most likely have to replace your ESC and your race day will probably be over, so why would you not pay attention while doing this? It's not hard. You just have to open your eyes.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-14-2014, 10:49 AM   #26
Trader Rating: 17 (95%+)
IMO, Dean's are hard as hell to solder. But I do love them.
Pintobean11 is offline   Reply With Quote
Old 08-14-2014, 12:48 PM   #27
theproffesor's Avatar
Trader Rating: 58 (100%+)
Been back into RC for a couple years now and NEVER plugged ky stuff up backwards. I paint the + terminal on my batts red, and all + wires are either red or have red shrink wrap on the ends. In addition my + wire from ESC is too short to reach the - side of the batt.
I ran deans years ago back in the nicd days because I didnt want to solder in my batts every time. But even with deans you have to be carefull if you ever use anyone elses stuff. They may not have the polarity the same as yours and poof there goes your ESC. At least with bulletts your stuff becomes fairly universal if you keep a pigtail in your pit box.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-14-2014, 01:59 PM   #28
Denial's not just a river in Egypt.
To re-use an old racers' adage... There's two kinds of people who use bullet plugs. Those who have connected them backwards, and those who will connect them backwards. You'll get your turn someday.
That said, I still use bullets. It's just a lot cleaner, particularly because of the balance wire on dean's packs. When I ran Schumacher, I did it because it's a a few grams lighter, but now it's just a question of tidy wiring.
I've only plugged in backwards probably 2-3 times, and every time it was due to trying to use batteries that had the opposite plug orientation to what I was used to, and I was distracted just at the moment I was plugging in the batteries. I've also loaned a battery to someone else and watched as they immediately plugged the wires in backwards.
-Mike
Old 08-14-2014, 02:20 PM   #29
Suspended
I always carry a roll of Red electrical tape and mark my bullet plugs and batterys with it on those that have bullets on pack.. I run high amp draw esc with high amp motors and have never had any issue with deans xt..
Old 08-14-2014, 02:25 PM   #30
RCNutJob's Avatar
Trader Rating: 31 (100%+)
Plug a male and female together before soldering them, that will keep the plugs lined up and allow for easy plugging in and unplugging.
I've been using Deans and the knock off ribbed ones from hobbyking for years and years, never had a problem with them on anything I own, even 1/8 stuff and big monster trucks.
| CEN Colossus GST-E |
| Stampede 4x4 | Stampede |
| Slash MT | Blitz |
| Futaba 4PLS |
| Shelfers - Lunchbox |
RCNutJob is offline   Reply With Quote
