Old 09-01-2005, 06:05 AM   #1
rbridd's Avatar
Default Help: Transmitter constant glitching
Hi all,
I bought an old Sanwa Gemini Exerd from Ebay. It was described as "untested". It seemed like a good idea at the time to have some sort of spare 40mhz tranny, for emergencies.
When I received it, I charged up the nicads, and tested it.
Yes, you are correct... It doesn't work.
When it's all connected up with a 40FM crystal inserted, the servo and ESC in the car just go mental. I'm not talking about some slight twitchy glitching here. I'm talking about full lock to lock servo arm movement, and the motor/ESC going absolutely bonkers. Input on the control sticks makes no discernable difference to the glitching.
Now; I'm testing with a KO receiver and KO crystals.
My expectations having been set because my KO transmitter and crystals work with a variety of receivers including KO, (obviously), Hitec, Novak, and Futaba.
So to my questions.
1. Is the Sanwa gear particularly fussy about matching hardware and crystals. So much so that we would see the behaviour explained above with non Sanwa equipment?
2. If the Sanwa Transmitter should work with non Sanwa Rx and crystals, at least in principle, then the Tx is FUBARED. I've opened it up, and there are no obvious blackened components on the circuit boards, so what could be wrong with it?
3. ... and how can I test and repair it?
Grateful for any input. I'ts really not worth spending a huge amount on such an old piece of equipment, so the ultimate option is simply to write it down to experience and bin the thing.
rbridd is offline   Reply With Quote
Old 09-01-2005, 11:59 AM   #2
With a Sanwa transmitter you MUST use Sanwa crystals. It will work fine with a Futaba reciever I run them in all my cars with a super exces tranny. Futaba and KO crystals do not mix with a Sanwa radio.
Jason B
jasonb is offline   Reply With Quote
Old 09-01-2005, 12:15 PM   #3
Default sanwa radio
i agree with jason u need sanwa xtals
brooksy is offline   Reply With Quote
Old 09-01-2005, 01:03 PM   #4
rbridd's Avatar
Thanks guys.
I'll try borrowing some from a Sanwa owner at my next race meet.
Can I assume that crystals for the Gemini2 will work in the Gemini1?
Or put another way, are all 40FM Sanwa/Airtronics crystals the same?
Old 09-01-2005, 01:28 PM   #5
Isn't Sanwa another name for Airtronics?
andsetinn is offline   Reply With Quote
Old 09-01-2005, 02:13 PM   #6
rbridd's Avatar
Yes.
As I understand it... Airtronics in the US, Sanwa elsewhere.
Losi Constant Velocity Drive (LCD) vs MIP CVD John Stranahan Electric On-Road 263 01-24-2010 12:51 PM
ORION CRF Constant Pressure Device CPD RC MARKET Nitro On-Road 3 10-06-2007 09:21 AM
Team Orion’s Constant Pressure Device (CPD) afm Onroad Nitro Engine Zone 13 02-06-2007 12:55 AM
fast charging transmitter pack whilst still in transmitter Xrayskid Electric On-Road 2 02-06-2006 04:16 PM
Gear Ratio Constant? trey Nitro On-Road 2 11-02-2003 05:28 AM
