Old 07-30-2014, 04:13 PM   #1
Salkin's Avatar
Default Tamiya TRF417V5 gearing help
New to onroad. Race 1/8 E buggy.
Have got a TRF417V5 that I plan to run on medium/large outdoor asphalt tracks.
The car is fitted with a 103T spur and I have several pinion gears (43, 44, 45, 47 and 48).
I have no clue about gearing the car. Can't find any clear information that helps me in my specific situation.
Can I use any of my pinion gears with the 103T spur gear on medium/large outdoor asphalt tracks without damaging anything, or are they totally "out of range"?
I run a Speed Passion GT2.0 Pro in default settings, and a Speed Passion 7.5T motor with the timing endbell set to medium (in the middle).
Thanks!
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 07-30-2014, 04:50 PM   #2
Thanks!
You want to ask the guys at the track what FDR they run. Then to caclulate it for the 417v5 you just need the following
(Spur gear / pinion) * internal ratio = FDR
The 417 has an internal ratio of 1.9473
So you can work out the pinion you need by redoing the calculation e.g
103/43 * 1.9473 = a FDR of 4.66
Personally I think you need a higher FDR to start out with (around 6) so fit the smallest pinion you have now but check at your club and see what they suggest
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-30-2014, 05:43 PM   #3
Salkin's Avatar
Thanks for your answer.
Yes, I saw the FDR calculation in the TRF417 manual and made the calculation and realized, that the FDR with a 103T/43T was in the lowest part of the FDR charts in the manual.
I will ask at the track, at keep an eye on temps until I get it sorted out-
Old 01-17-2016, 06:00 AM   #4
Default trf 417 gearing
hi please can anyone help i got a TRF417v5 what pinion will be best to start with on a medium size carpet track. my spur gear is 111t motor lrp x20 13,5 t
petepn is offline   Reply With Quote
Old 01-17-2016, 02:15 PM   #5
111 is a large (too large) spur for 13.5 and will need a pinion in the 50t range to get an acceptable FDR (around 3.9-4.1 as a start with an X20, if zero timing ESC). Not actually even sure a 50+ will fit under the top deck to be honest.
Get a 96 and things will be much easier.
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
