Old 07-30-2014, 12:47 AM   #1
Mikkel_R's Avatar
Default Lipo condition
What is a good internal resistance for a Lipo in good condition?
Ive got three packs with varying resistance but not sure if they are getting old or faulty.
Pack 1 Orion 7.4v 5000 90c 9.8 m ohms
Pack 2 Orion 7.4v 5000 90c 11.1 m ohms
Pack 3 LRP 7.4v 7200 100c 3.7 m ohms
All these reading are taking form the LRP touch charger.
Also i'm wanting to get new lipo packs, instead of looking at the "c" rating are you better comparing the wattage of the packs?
Cheers Mike
Mikkel_R is offline   Reply With Quote
Old 07-30-2014, 12:55 AM   #2
Anything lower than 3 ohms per cell is really good in my book.
Minh Nguyen
[Maclan Racing] [Xpert Servos]
trigger is offline   Reply With Quote
Old 07-30-2014, 02:12 AM   #3
Mikkel_R's Avatar
Do you know if the LRP Touch reads the IR as a pack or per cell e.g. Is my Orion pack 9.8m ohms overall or per cell.
Old 07-30-2014, 02:46 AM   #4
Skiddins's Avatar
There are only a few charges that give accurate results for IR, that charger isn't one of them
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-30-2014, 03:04 AM   #5
Mikkel_R's Avatar
Which chargers or stand alone devices give accurate IR readings?
Old 07-30-2014, 09:53 AM   #6
dave-man's Avatar
Trader Rating: 17 (100%+)
iCharger
dave-man is offline   Reply With Quote
Old 07-30-2014, 10:03 AM   #7
Trader Rating: 32 (100%+)
Originally Posted by dave-man View Post
iCharger
Which model???
hobbs is offline   Reply With Quote
Old 07-30-2014, 01:13 PM   #8
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by hobbs View Post
Which model???
The 4010, 406, and 308 will all give IR while charging or whenever you want to check by pushing a button. My orcas stay at about 1.0-1.3 per cell and I charge on an icharger at 20+ Amps everytime.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-30-2014, 07:17 PM   #9
theclutch's Avatar
On what basis or reasoning did you find the iCharger to be the best at measuring resistance? I.e. - if I bought the iCharger and compared it to my other chargers, how do I know which one is correct?
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 07-31-2014, 03:22 AM   #10
Skiddins's Avatar
I've never used an iCharger (I wasn't the person who said they were good at it )
I don't think any charger can be accurate if trying to measure internal resistance while charging, if it stops to take the measurements that's different.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 07-31-2014, 06:08 AM   #11
dave-man's Avatar
I can check the IR of my battery without it being charged. I hold down a button and it takes 5-6 seconds to show my IR.
I am not an IR guru or anything. I just know the lower the number the better. However, I'm not sure what all affects the reading. Would longer/shorter cables give you a different reading? Would thicker charging cables give you a better reading? I need to play around it with it more to find this stuff out.
Old 07-31-2014, 07:11 AM   #12
Conrad's Avatar
I used the Nosram Stealth (same as LRP but in red) and I found it always read high for IR but as long as you keep a record of the IR numbers from new until just now you still have a point of reference to compare the quality of your cells on your charger.
As far as charger IR results go, Danny from SMC put up results from a few chargers on there Facebook page a few months back:
Internal Resistance measurements on chargers can be misleading. On the most part they give you a good idea on your packs performance but they can't be trusted 100% like you can trust the ESR IR meter which is accurate.
Here is a test I did to show how IR readings on chargers can be misleading. I have 3 chargers that will give IR readings. One of them is the Revolectrix Powerlab the other is the iCharger 4010 Duo and the third is the Competition Electronics Turbo 35 GFX that gives IR under discharge. The other chargers give IR under charge.
I'm not sure how the Revolectrix measures the IR as it seems to be off compared to the iCharger and ESR meter. On some packs it seems to be closer to the iCharger and ESR meter but on others it's way off.
To show what I mean I did a test using a cheap 6200-30C-3S pack using the big long style cells that a company sent me for testing awhile ago. I'm also testing one of our 4300-40C-3S pack that fits in our 2S hardcase. This test also shows why you can't trust C rates.
Here are the IR numbers for each cell in the pack.
6200-30C-3S
Revolectrix IR: 3.1 - 2.9 - 2.9
iCharger IR: 7.5 - 9.3 - 6.5
ESR meter IR: 7.37 - 8.37 - 6.51
GFX discharge data: 5722mAh - 11.06 Avg.V - 15.2 IR
4300-30C-3S
Revolectrix IR: 2.7 - 2.5 - 3.2
iCharger IR: 3.5 - 3.7 - 3.6
ESR meter IR: 3.83 - 3.95 - 4.09
GFA discharge data: 4326mAh - 11.17 Avg.V - 9.0 IR
As you can see the Revolectrix gives better IR on the big 6200 pack but the iCharger , ESR meter and GFX all give better IR on the 4300 smaller pack. Based on this racers/customers need to be cautious when using the IR provided by chargers. I trust the ESR meter and the GFX and the Duo is not perfect but seems to be closer to the ESR meter than the Revolectrix. On some packs the Revolectrix does give a more reliable IR.
Another thing to note if you want to find which of your packs has the best IR you need to test them at the same temperature and charge rate. Temperature has a big impact on IR and the charge rate as well as it can get the cells hotter depending of the rate you're using.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 07-31-2014, 08:40 AM   #13
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Interesting
If my GFX showed I.R. numbers that high, I would toss that lipo pack
Also, the LRP touch has shown very consistent numbers in my experience, albeit on avg 2 pts higher than other hardware
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-31-2014, 08:48 AM   #14
tessty71's Avatar
Trader Rating: 16 (100%+)
SMC has a stand alone IR device
http://www.smc-racing.net/index.php?...product_id=103
KSG SCX / C&M Mortorsports
Point R/C Raceway
tessty71 is offline   Reply With Quote
Old 07-31-2014, 01:05 PM   #15
Skiddins's Avatar
Originally Posted by tessty71 View Post
That's the ESR meter mentioned in some of the above posts.
It's also what I use
Xray X12 2018
Xray X1'16
RCDisco.co.uk
