Old 07-31-2014, 01:22 PM   #16
Suspended
No charger or IR device is true.. They all state THE IR is estimated..
The only true way is to apply OHM's law..
Build a light dis-charger..I have 3 or different amperage's from 5 amp draw to 50 amp draw
also needed is a Good watt meter and a pad of paper to write down your results..
These things can be done for under $40 if you shop around..
$6 at local dollar store for car lights
a couple of connectors.$5
wire $2
watts meter $25 Tops -got mine for $15 wattsup
no need to buy a IR meter that states all IR measurements are estimated when you can have Non estimated results and #'s
a Good IR measurement is anything under 15 milla ohms per cell
just ask .I may know the ANSWER !
ElectricMann is offline   Reply With Quote
Old 07-31-2014, 01:32 PM   #17
dan_vector's Avatar
Trader Rating: 27 (100%+)
Even if chargers are estimating the pack IR or is displaying IR which is incorrect. Isn't it still a satisfactory way of at least comparing packs on the same charger to see which of your packs has the lowest IR and therefore better punch?
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-31-2014, 01:37 PM   #18
Suspended
for you sure... for me NO.. I deal in truths and as you are well aware of this hobby does not allow that to be it is full of junk and worse..don't wanta violate any rules on this forum by saying THE TRUTH.. I see what happens to people who don't go with the majority they get the giant boot so the liars can run free
This is how I see things We have battery's that can put out 200 amps easy and that amount of power can hurt or kill a person if there face is in wrong place or any other vital thing can of gas
Old 07-31-2014, 02:09 PM   #19
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
care to back that statement up?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-31-2014, 02:12 PM   #20
Super Moderator
racer1812's Avatar
As far as IR readings, I use my Hyperion to gauge the condition of my packs through their life cycle as well as pack to pack comparisons. It's impossible to compare the IR numbers from charger to charger, even of the same brand.
Old 07-31-2014, 03:53 PM   #21
Skiddins's Avatar
wire $2
The problem with light bulbs is that their resistance varies with temperature just like everything else, but electronic circuits aren't quite so susceptible to it. Also, you are measuring all the joints in your lightbulb discharger as well as the bulbs themselves, so you are not getting the most accurate reading.
When they state estimates on meters and chargers, they aren't saying they are wildly inaccurate just not 100%.
If I had a pack that was 15milliohms per cell I'd be using it as a doorstop, I have thrown worse than that out.
I have a pack that measures (on my ESR meter) 7-10milliohms per cell and packs that have 2-3millohms per cell.
I can tell the difference on the track with the amount of punch.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-31-2014, 05:09 PM   #22
Originally Posted by Mikkel_R View Post
What is a good internal resistance for a Lipo in good condition?
Ive got three packs with varying resistance but not sure if they are getting old or faulty.
Pack 1 Orion 7.4v 5000 90c 9.8 m ohms
Pack 2 Orion 7.4v 5000 90c 11.1 m ohms
Pack 3 LRP 7.4v 7200 100c 3.7 m ohms
All these reading are taking form the LRP touch charger.
Also i'm wanting to get new lipo packs, instead of looking at the "c" rating are you better comparing the wattage of the packs?
Cheers Mike
Your results appear to be in the ball park of what I would expect for those cells.
Although perfectly accuracy would be great I doubt any device including the icharger is. Trying to measure IR under 10 mohm with a cost effective device accurately is not easy.
I would suggest you can take comparative results with your charger use the results to monitor the condition of the packs. ie when a pack is new at 50 cycles, 100 cycles 200 cycles ect.
frozenpod is offline   Reply With Quote
Old 07-31-2014, 05:16 PM   #23
Dead right skiddins.
Measuring the IR of a battery is not so simple.
Electricmann
You need accurate measurement of voltage and current whilst also taking into account voltage drop due to the change in capacity.
Light bulbs and a watt meter be unlikely to be accurate enough for meaningful results.
I think some IR measurements are made with an estimation of battery capacity hence the statement of estimated IR.
Some dischargers will estimate the capacity of the battery by discharging for 60 seconds before taking an IR measurement. The first 60 seconds of discharge provides enough information for a very accurate estimation of battery capacity.
Some chargers whilst charging may do the same before taking the IR measurement.
Old 07-31-2014, 05:30 PM   #24
Suspended
Wayne Giles himself has said this in a few posts...
sorry but as long as you record amperage.. and voltage difference you have a IR that is actual not estimated..
Old 07-31-2014, 06:00 PM   #25
Only if it is an instantaneous measurement.
Measuring IR when the values in so low often in the order of 1-3 mohm accurately in real world is a non trivial exercise.
Old 08-01-2014, 06:36 AM   #26
Conrad's Avatar
Just like the CE TurboGFX, it's the only one that measures IR on discharge and is probably the most accurate and reliable device out there.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
