Old 07-28-2014, 05:12 AM   #1
breakbruce's Avatar
Default Car fully working except it won't move
I have a TA-05 with all components working, except when I push the throttle or reverse nothing happens. The steering works and the electric motor also works except it doesn't rev when I push the throttle. Any idea how I can fix this? Thanks!
Motor & ESC:
http://www.rcmart.com/speed-passion-...o-p-27270.html
breakbruce is offline   Reply With Quote
Old 07-28-2014, 05:19 AM   #2
Suspended
how do you know motor works ? car is not moving
so
Pull pinion and test motor esc that way.. if it spins then you need to check your drive train.. start from wheels work in to motor mount ..
wheel nuts to tight
hub bearings froze
front diffs spins freely main drive spins freely
main diff spins freely
rear diff and wheel bearing should have done when u checked fronts..
other wise good ole speed passion stuff LOL..
just ask .I may know the ANSWER !
ElectricMann is offline   Reply With Quote
Old 07-28-2014, 05:32 AM   #3
cartix's Avatar
Trader Rating: 33 (100%+)
Did you program the ESC to the transmitter?
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 07-28-2014, 06:42 AM   #4
breakbruce's Avatar
so
wheel nuts to tight
hub bearings froze
I could hear the motor hum, but yea, I'll go through ur check list, thanks!
To the receiver yes, but I don't recall programming the esc to the transmitter.
Old 07-28-2014, 08:26 AM   #5
niznai's Avatar
That doesn't mean the motor works. Do the ESC thing to the transmitter and try again.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-28-2014, 08:52 AM   #6
theproffesor's Avatar
Trader Rating: 58 (100%+)
How tight is your gear mesh. There should be just the slightest bit of play between pinion and spur.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 07-28-2014, 09:30 AM   #7
Slotmachine's Avatar
Send a message via MSN to Slotmachine
If it is a sensored motor and you have the ABC wires in the wrong order it wont run.
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-05-2014, 09:03 AM   #8
breakbruce's Avatar
Thanks for all your help guys. Turns out it was a fried ESC.
