Old 08-31-2005, 01:49 PM   #1
Default How to make fans on a switch...
Hello all, i would like to know how to make the cooling fans in my car be on a switch.Can anybody show/tell me how...Thanks
XrayFK05 is offline   Reply With Quote
Old 08-31-2005, 01:54 PM   #2
ChadCapece's Avatar
Get a switch from radio shack. Or best would be out of a radio kit that has the switch for nitro cars. Solder that from the pos and neg batter wires to the fans.
ChadCapece is offline   Reply With Quote
Old 08-31-2005, 02:00 PM   #3
anybody have pics of how to do this??
Old 08-31-2005, 02:12 PM   #4
raving-monkey's Avatar
Send a message via MSN to raving-monkey
wouldnt that just short the batts out when you had the switch closed...and allow the fans to work when it was open?
easiest way would be to put it in the pos OR neg wire to the fan...ie so when it is open it breaks the circuit stopping the fans...when its closed it lets the fans run as it completes the circuit
raving-monkey is offline   Reply With Quote
Old 08-31-2005, 02:14 PM   #5
Ducati-Rider's Avatar
Default plug into receiver
I just plug mine into an open servo port on the receiver and it comes on when I turn on the receiver.
Ducati-Rider is offline   Reply With Quote
Old 08-31-2005, 02:18 PM   #6
oh, ok i get it now.... Thanks
Old 08-31-2005, 02:51 PM   #7
yeah but putting the fans onto a switch...direct to the battery wires..
you can switch off the esc but still have the fans running so your motor cools down while your marshalling
Old 08-31-2005, 07:28 PM   #8
I used an old speed control on / off switch. There are 2 wires from the fan and I ran them to the + and - on the speed control. I cut one of those wires and soildered the old switch so it either conects or breaks the current to the fan. Can leave it on after running, or turn if off anytime a battery is connected.
pops is offline   Reply With Quote
Old 08-31-2005, 07:39 PM   #9
ChadCapece's Avatar
No, it doesn't pull power (short) from the batteries b/c the circuit is broken. The switch lets you run your fan in the pits. Or before the race.
Old 08-31-2005, 08:21 PM   #10
xDeeDubYax's Avatar
Just use the third channel of your receiver, and turn it off and on from your transmitter. Most three channel radios have a dial to adjust the third channel. The great thing about this? It is only on when you turn the dial. If you have a minute call at the start of the race, your car isnt on the line with the fan(s) running and taking the peak off of your cells.
- DaveW
xDeeDubYax is offline   Reply With Quote
Old 09-01-2005, 12:06 AM   #11
yeah but as soon as you close the switch it willshort out the batteries becauseyou are basically putting a jumper wire accross them.
Old 09-01-2005, 12:10 AM   #12
A Ilievski's Avatar
Trader Rating: 39 (100%+)
i got a motor fan today, its specs are
uses 12v/0.15amp and its 5cm by 5cm and 1cm thick,
i was wondering would this be a good fan for rc car motors, also how much power would it drain.
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 09-01-2005, 12:49 AM   #13
loopedeloop's Avatar
[email protected]=1.8Watts........ is the power drain
Or in laymans terms it will take 10hrs to drain a 1500 battery.
loopedeloop is offline   Reply With Quote
Old 09-01-2005, 12:56 AM   #14
A Ilievski's Avatar
so it woudnt make much difference to the power of a 3300 if i was to use it in 540 races
Alex Ilievski
Old 09-01-2005, 01:06 AM   #15
nah mate.
It certainly cant do any harm and you wont notice the difference at all I wouldnt think.
It will however allow you to run a slightly higher gearing before cooking your motor.
And might help in that aussie heat too
how to make 3 prong deans to easily switch Brushless to brush? Valentin.H Electric On-Road 20 03-04-2007 09:44 PM
MUCH MORE fans surrealmaterial Electric On-Road 10 02-12-2007 11:18 PM
FANS???????? serpentrush Electric On-Road 8 01-11-2006 08:15 PM
#88 Fans This is a Must Have K1WEY R/C Items: For Sale/Trade 0 12-12-2003 10:44 AM
HPI fans hyperformance R/C Items: For Sale/Trade 8 03-03-2002 05:07 PM
