Advance R/C Car R10 2015
#1023
Got to test the new Avid Aluminum chassis today. Must say this chassis is legit. Little bit more forgiving than the stock aluminum chassis which translate to better traction on the front end of the car. I ran long shocks early on which clocked competitive times[green fronts, blue rears(green/green too loose)]. I then switched to short shocks running progressive fronts and linear rears which allowed the car to dive into corners better. Short cambers links all the way around.
#1025
Hello
just got a r10 2015 arc .what diff oil would you start with to run 17.5 stock on a large asphalt medium grip
outside track..thanks
#1027
#1028
Never had a gear diff always used a ball diff. Though I would try a car with a gear diff and already ordered the wrong stuff lol
#1031
Is this on sale anywhere?
#1032
#1033
New, I doubt any vendors have it in stock any more. The R11's are what is being stocked now. I believe they are due in stock next week.
http://hobby-square.com/arc-r11-car-kit/
#1035
Hello out there on the internets
Is anyone still running the 2015 car? I just finished rebuilding my car, and i am setting up my car for a light/medium grip asphalt, with yokomo pink and blue springs. i'm starting with the kit's base setup but with the floating front mount
This is for USGT 21.5t
