Advance R/C Car R10 2015 >
Old 09-29-2015, 11:42 PM
  #976
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by trigger View Post
I would like to Congratulate Frank Root with his new born baby daughter!
Thanks Minh!!
Frank Root is offline
Old 09-30-2015, 12:04 PM
  #977
Originally Posted by Carnage9270 View Post
Should be the first place to get them.
http://hobby-square.com/avid-rc-arc-...minum-chassis/
In stock!
A_Cartwright is offline
Old 09-30-2015, 12:33 PM
  #978
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by A_Cartwright View Post
In stock!
mine s/b tomorrow at my front door step..
OVA is offline
Old 09-30-2015, 12:47 PM
  #979
Mine's sitting on my table looking all sexy. My first scratch on this thing is going to make me a very sad person.
#ShelfQueen
Carnage9270 is offline
Old 09-30-2015, 01:08 PM
  #980
Ohhhhh the chassis.....
Old 09-30-2015, 01:27 PM
  #981
Chassis? OHHHH yeah, that too.
Old 10-01-2015, 07:14 AM
  #982
Professor's Avatar
Originally Posted by JCarr View Post
Been running the car a while now and have an issue that I can't seem to figure out. It seems to chew up the inside edge of the tires in about 3 race days. I'm only running 1.5* camber which is less than what I ran on my previous car and tires would last almost a whole season. I remember reading somewhere about if your springs are too hard or too soft it could cause this issue, but can't seem to find that info now. I'm running kit set up except that I have no shims under the rear suspension mounts. Anybody have any suggestion as to what I can do to to slow down the tires wear?
You could try increasing droop by 1mm all round, my arc & vbc did exactly what you have described,I did this on both cars & increased the longevity of the tyres to double what I was getting previously,but didn't loose any corner speed or handling characteristics ( I ran kit droop settings on both cars before the increase ) hope this may help you
Professor is offline
Old 10-01-2015, 08:19 AM
  #983
OVA
OVA's Avatar
#ShelfQueen
Hey Mike
You have the carpet set up sheet with Alum chassis?
OVA is offline
  #984
JCarr's Avatar
Thanks Professor, I may try that the next time I get out. What I did last week was go softer on the springs all the way around and it seemed to even the wear out better. I had been taking away rear droop because the back end was loose off power.
JCarr is offline
Old 10-01-2015, 08:45 AM
  #985
Trader Rating: 2 (75%+)
What's a good fdr to aim for when running mod? I'm going to run either a 4.0 or 4.5T mod motor and I'm not sure what the fdr should be around?
kingtito is offline
Old 10-01-2015, 09:35 AM
  #986
Originally Posted by OVA View Post
Hey Mike
Depends on what shocks you're running. Short or long?
Old 10-01-2015, 10:21 AM
  #987
TLRacing
Frank Root's Avatar
I run around an 8.0 with my Orion stuff, including the boost in ESC.
Old 10-01-2015, 10:28 AM
  #988
OVA
OVA's Avatar
I have them both, what is your ?
OVA is offline
Old 10-01-2015, 02:24 PM
  #989
Thanks Frank.
kingtito is offline
Old 10-02-2015, 12:12 AM
  #990
pauld's Avatar
Congrats Frank.
pauld is offline
