Advance R/C Car R10 2015 >
Old 08-26-2015, 11:09 AM
  #961
The LSF body seems to be the go-to body for asphalt right now, although i prefer the GSF. For carpet I use the GSF only.
Carnage9270 is offline
Old 08-26-2015, 04:35 PM
  #962
Luppi Stefano's Avatar
Thanks!
anyone?
Luppi Stefano is offline
Old 08-27-2015, 08:49 AM
  #963
nikos2002's Avatar
Trader Rating: 30 (100%+)
nikos2002 is offline
Old 09-17-2015, 01:00 PM
  #964
Hey guys! Next year i wll be racing My ARC with 13.5T Blinky.
Whats advices for gearing ?
Between 4,0 and 5,0 ?
At the ARC 2015 what is the range acceptable for spur and pinion (Highest and lowest).
Thanks a lot.
Regards
piorc is offline
Old 09-17-2015, 03:24 PM
  #965
with 90T spur, perfect for Stock...
36T Pinion 5 FDR
40T Pinion 4.5 FDR
45T pinion 4 FDR
Old 09-19-2015, 01:21 PM
  #966
Thanks a lot.
Regards
There is not a lot of room for gears in the R10. A 3.9 FDR seems to work very well on medium sized outdoor asphalt tracks. I run a 94/48. I have a 90/47 as well, but haven't needed it yet.
LAGuy is offline
Old 09-20-2015, 03:33 PM
  #967
Thanks a lot !
piorc is offline
Old 09-23-2015, 06:23 AM
  #968
JCarr's Avatar
Been running the car a while now and have an issue that I can't seem to figure out. It seems to chew up the inside edge of the tires in about 3 race days. I'm only running 1.5* camber which is less than what I ran on my previous car and tires would last almost a whole season. I remember reading somewhere about if your springs are too hard or too soft it could cause this issue, but can't seem to find that info now. I'm running kit set up except that I have no shims under the rear suspension mounts. Anybody have any suggestion as to what I can do to to slow down the tires wear?
JCarr is offline
Old 09-23-2015, 06:56 AM
  #969
Trader Rating: 6 (88%+)
new aluminum chassi from AVID !!
http://www.avidrc.com/product/5/acce...cessories.html
Quinny45 is offline
Old 09-23-2015, 07:51 AM
  #970
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Quinny45 View Post
it is out of stock
OVA is offline
Old 09-24-2015, 06:13 AM
  #971
If everybody take the notification they come in stock more fast i think
Quinny45 is offline
Old 09-24-2015, 08:46 AM
  #972
liposkippy's Avatar
I am ordering my new kits and wondering what toe blocks, and sway bars come in the kit so i can get the proper tuning options. springs as well.
recommendations?
liposkippy is offline
Old 09-24-2015, 09:44 AM
  #973
Originally Posted by OVA View Post
it is out of stock
Should be the first place to get them.
http://hobby-square.com/avid-rc-arc-...minum-chassis/
Old 09-24-2015, 09:53 AM
  #974
recommendations?
Kit comes with a 2, 1, 0, and a 3 toe blocks. Sway bars are 1.4 in front and 1.2 in rear.
Take a look at the stock setup sheet, it'll give you everything that is included.
Old 09-29-2015, 07:04 PM
  #975
Trader Rating: 15 (100%+)
I would like to Congratulate Frank Root with his new born baby daughter!
trigger is offline
