Advance R/C Car R10 2015 >
Old 05-31-2015, 07:22 PM
  #886
Scott B's Avatar
Trader Rating: 45 (100%+)
Originally Posted by nikos2002 View Post
http://ets.redrc.net/2015/05/chassis...rik-heitsch-3/
Henrik showing off the new LSF and some other goodies coming in the future....
Looks good Nick.. When do you think you will have the new steering in stock???
But I'm not sure if my ARC can get much better, it's been working great in USGT for me for the past few months.. . Won our 6race Porsche Cup series we had and TQ'd and won today in a field of 16 cars in USGT. Ohhhhh and another ARC finished 2nd in the series as well...
And I have a 2nd car coming for 13.5...
Scott B is offline
Old 06-02-2015, 06:21 AM
  #887
nikos2002's Avatar
Trader Rating: 30 (100%+)
Henrik said 4-5 weeks in the RedRc.net post.
Congrats on the wins!!!! Tell your friends!!!!
nikos2002 is offline
Old 06-02-2015, 08:20 AM
  #888
JCarr's Avatar
Have an R10 2015 on order through my LHS, can't wait to get it in my stable.
JCarr is online now
Old 06-02-2015, 05:59 PM
  #889
Trader Rating: 15 (100%+)
You will love it. Rear diff bearing carriers are an area to focus on during assembly to keep drivetrain free. Other than that and shock lengths, you should be good.
trigger is offline
Old 06-02-2015, 06:19 PM
  #890
Hey guys,
I just bought one ARC R10 2015.
There are some advices for the building ?
I will race on asphalt outdoors. High bite tracks.
I'm new on touring competition cars.
Thanks a lot
piorc is offline
Old 06-03-2015, 10:20 AM
  #891
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Originally Posted by piorc View Post
Hey guys,
Thanks a lot
Have a cup of coffee. Grab a pen and some paper. Start reading from page one of this thread. Take some notes. Lots of good tips and also try going to ARC facebook page.
Josh-n-ya is offline
Old 06-03-2015, 09:17 PM
  #892
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Hey guys,
Thanks a lot
Best advice, take your time when building your kit.
Ivan Dickson is offline
Old 06-04-2015, 07:41 AM
  #893
Need some help. Can anybody tell me what part r105402 is. It is on page 5 of the 2015 R10 manual. It looks like a ball end that fits inside the steering ball joint. I cannot find this part at any distributor's web site.
jammin684 is offline
Old 06-04-2015, 08:08 AM
  #894
It is a 3x4 grub screw. Also know as a "set screw". I want to say there is a little bag with a few extra screws and set screw in one of the last bags in the kit.
What that screw does is hold the outer hing pin in place. Keep building the kit and you might end up finding that part in the another bag. Everything in the box section of the manual is considered hardware. Screws and washers.
http://www.amain.com/rc-cars/yokomo-...c-ss34/p257388
Kody is offline
Old 06-04-2015, 08:12 AM
  #895
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
It's a set screw. Goes into the bottom of the caster block to hold the hinge pin in place.
Attached Thumbnails Advance R/C Car R10 2015-arc.jpg
Frank Root is offline
Old 06-04-2015, 09:26 AM
  #896
Thanks Kody and Frank. I believe I was looking at the drawing wrong and for some reason thought it was some sort of bushing for the steering linkage.
Old 06-05-2015, 06:34 PM
  #897
Solved the issue... disregard post.
LAGuy is offline
Old 06-06-2015, 06:48 AM
  #898
Found the bracket suspension chart and realize the .5/1 refers to the positioning of the split bracket and the roll enter shim listed is correct. I thought the .5/1 referred to the shim under the split block.
LAGuy is offline
Old 06-06-2015, 06:59 AM
  #899
Originally Posted by Kody View Post
Great to have another join the forces. The R10 is a solid car that's slowly gaining attention in the US.
Kit setup is a great starting setup for asphalt. Few small tweaks I'd recommend are HPI Silvers springs front/rear, AE 3 or 5k in gear diff and off you go! Top it off with a Blitz GSF body and its a super easy and fast starting point.
What surface and class will you be racing on? If your running stock classes I'd recommend Low friction belts and possible the LF pulley set to get that extra out of the drive train. For a little more steering over kit setup split blocks are a great option for the front. Also rear DCJ's to really make the rear rotate and carry corner speed.
For carpet check out my IIC setup. Its been a great starting point for many on US carpet tracks. http://www.petitrc.com/reglages/arc/...etsARCR10.html
I'll be running 13.5 on asphalt. How would you setup the split blocks front and rear with the kit setup or with Henrik's 13.5 setup? Thanks!
LAGuy is offline
Old 06-06-2015, 09:37 AM
  #900
Scott B's Avatar
I'd say start with the front/rear blocks in the 1d so notch on the inside and the rear/front with the notch out so .5d less rear toe and a little wider in the rear
You can swap them around and see how the change feels for you and what you may like better..
Scott B is offline
