Advance R/C Car R10 2015
#828
Happened to me with hard and soft arms, its pretty annoying
#831
mine should be here in 2 weeks time and on the track before June.
With all the reviews and people saying soo much good about this car, someone tell us, what is the weak link, what spares are needed, what is needed from box stock as tuning options excluding a different chassis plate?
#832
Sorry to hear your having such bad luck with this. I've never seen 1 ball break up here in the NW from guys racing on the track and most including myself have had some bad crashes. Popping them on and off we've had 2 arms out of more then 20+ kits local. Is the ball just breaking or is it popping off when other items break?
I've found using a larger flat head screw driver wedged between the arm and ball cup is a great way to pop the cup on straight/easy.
#834
Kit setup is a great starting setup for asphalt. Few small tweaks I'd recommend are HPI Silvers springs front/rear, AE 3 or 5k in gear diff and off you go! Top it off with a Blitz GSF body and its a super easy and fast starting point.
What surface and class will you be racing on? If your running stock classes I'd recommend Low friction belts and possible the LF pulley set to get that extra out of the drive train. For a little more steering over kit setup split blocks are a great option for the front. Also rear DCJ's to really make the rear rotate and carry corner speed.
For carpet check out my IIC setup. Its been a great starting point for many on US carpet tracks. http://www.petitrc.com/reglages/arc/...etsARCR10.html
#836
#837
They are in stock now. Have your hobby shop contact us, or check with www.hobby-square.com
#838
Yes kits were out for a few days from the distributor but came back in-stock last Tuesday. Price drop was announced the 25th. Not that it wasn't before but its an even better value for the performance and quality offered.
US Kit was something we wanted to offer to keep the original price down and there are no plans to change that from what I know.
Kody
Kody
#839
Kody
Kody
