Advance R/C Car R10 2015 >
Old 08-31-2014, 03:31 PM
  #136
Gridworks Racing's Avatar
Originally Posted by Josh-n-ya
Is it just me but when there is a lot of pics on a page my computer freezes up and I cant scroll???
It's just you :P
Gridworks Racing is offline
Old 08-31-2014, 03:42 PM
  #137
dawgmeat's Avatar
It's happening to my laptop also
dawgmeat is offline
Old 08-31-2014, 04:00 PM
  #138
b20btec's Avatar
I bought a kit to run blinky. Any reason why some of you guys are running hpi silvers before putting the car on the track? I run blinky TC weekly and mostly on carpet and once awhile on asphalt. Never needed to go up to 16.7 lbs spring. If it works it works, just curious.
b20btec is offline
Old 08-31-2014, 05:50 PM
  #139
HPI silver springs are the defacto asphalt spring, use whatever feels comfortable. I have yokomo pink and blues in my pics...again defacto springs for carpet. Usage varies for every driver
Carnage9270 is offline
Old 09-01-2014, 12:26 AM
  #140
mine felt fine with greens up front an blues out back. i might try a harder spring for carpet.
dragonracing is offline
Old 09-01-2014, 03:29 AM
  #141
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
+1 so far! No carpet for us here. Its called laid off till spring.
Just ordered conversion and 2.0 chassis to swap one of my 2013 to a 2015 for mod. Cant wait.
Josh-n-ya is offline
Old 09-01-2014, 03:38 AM
  #142
Josh-n-ya's Avatar
Originally Posted by nikos2002
Besercoe - curious about shimming the motor mount. Are you trying to run a fan wire under the motor? Raising the motor and in effect the whole top place? Thanks for the info.
Hey Nick! Was ordering more parts today and noticed the Green long springs for the 2015 are no longer even on the shopviper site? Whats up with that?
Old 09-01-2014, 08:33 AM
  #143
b20btec's Avatar
I was looking for the new green springs and all black toe blocks for the rear on viperrc also, any idea when they'll be in stock or is this a special order?
b20btec is offline
Old 09-01-2014, 01:33 PM
  #144
Ok, aside from the LF belts and pullies, what else should I get for options? How are those LF ball ends?
inpuressa is offline
Old 09-01-2014, 06:28 PM
  #145
carnage runs the low fric rod ends. he likes them. i dont have them and get zero bind so i dont think ill get them. But i just installed the low fric belts and pulley set and really worked over the bearing cups to get as little bind as possible yesterday. the car was fast today. If could have gotten a clean run i might have set tq but i did manage to eeek out a win today in 21.5 scale spec/vta.
I also ran the green springs and they felt too soft up front and went back to the yellows during qualifying and it felt better. it seems to get more steering with stiffer springs up front. had to raise the roll center in the back by removing the 1mm shims on the inside of the camber links and had great off power steering. the hpi d compound tires we have to run are hard as bricks so everything i can manage to eek out of them helps. thats the only change from the factory setting i have made so far. the car is so smooth its unreal.
Old 09-02-2014, 02:43 PM
  #146
nikos2002's Avatar
Trader Rating: 30 (100%+)
Josh - thanks for the call today. Yes it was a mix up on part numbers. We were out of stock, anyway. It will be fixed on the site and in our next order.
nikos2002 is offline
Old 09-02-2014, 02:44 PM
  #147
nikos2002's Avatar
Springs were part of the part number mix up listed above. We have not received the black toe blocks yet. Next order is due in early next week.
Nick/Viper
Old 09-02-2014, 03:03 PM
  #148
b20btec's Avatar
Nick/Viper
Ok thanks!
b20btec is offline
Old 09-03-2014, 06:14 AM
  #149
stiltskin's Avatar
Trader Rating: 103 (100%+)
I received my Black Edition yesterday and couldn't wait to get busy on the build. Thanks to Gridworks for getting my kit shipped out quickly. Always great customer service.
I sanded the diff bearing caps and it definitely frees up the drivetrain. Still have some work to do but I like to run a car before doing to many tips/tricks. Let it break it naturally. Plastic fitment was pretty snug in some places and required a little extra attention. I'll take sanding over shimming any day. 😉 Instructions are a little vague in places but pretty straight forward for the most part. The black edition came with a full set of the standard screws. I was about 10 screws in to the chassis before I realized there was a seperate bag with all the black hardware. Haha. Live and learn. The only real issues I had with the build were a rear axle that would not go through the bearing. I had to chuck it in the dremel and remove the coating to get the bearings to slide on. The other issue is play in the shock pistons. I'm used to shimming pistons except I can't find my shims, so that's frustrating. 😕. Overall, I'm very impressed with the kit. Mounting electronics tonight and putting it on the setup station. Can't wait to get it on the track. Thanks again to Lemar for hooking me up with a nice kit.
stiltskin is offline
Old 09-03-2014, 06:37 AM
  #150
Team EAM
Trader Rating: 79 (100%+)
If anyone is interested Kody Knudston (Sorry for spelling) just placed a large order with me for the ARC Titanium screw kits and also some special edition 2015 Screw kits all from Hiro Seiko. If any are interested in them for their cars you can contact him at [email protected] as he will be carrying the ARC kits.
He will also have the matching black and silver alumn shim kits, serrated wheel nuts and other items as well.
EA
EAMotorsports is offline
