Is iCharger really superior? >
Old 08-07-2014, 08:12 PM
  #106
vabroom's Avatar
Thanks, CarbonJoe, just got the Tuning Haus cord and was wondering why there was two 2mm plugs. Although I wish they had the female plug soldered the other way around, just might do that.
vabroom is offline
Old 08-07-2014, 08:59 PM
  #107
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Originally Posted by CarbonJoe View Post
When charging a 2s, the red balancing lead gets plugged into the 2mm tube on the red bullet plug, and the blue 2mm balancing wire plugs into the balancing port on the battery.
For a 1s pack, the blue balancing wire goes in the 2mm tube on the red bullet plug, and the red wire just hangs free.
again, thanks
Josh-n-ya is offline
Old 08-07-2014, 09:23 PM
  #108
FYI, I temped my 600mm/12 gauge charge leads last weekend. After a discharge down to 3.4v/cell followed by a 40amp charge for approximately 15 minutes, the Novak wire hit 115 degrees.
LAGuy is offline
Old 08-07-2014, 11:03 PM
  #109
Jsaves's Avatar
How do the ichargers discharge? Do they just use their internal components or do you have to hook a battery for higher discharge rates?
Thanks and God Bless
Jsaves is offline
Old 08-08-2014, 06:58 AM
  #110
Josh-n-ya's Avatar
Can someone give me a breakdown of what to do and charge at? Only going to be for 2s right now. I want to charge at 40a. I also need to know what to safely set it up at to discharge at and per cell. Can I discharge up to 40 amps? This is for a 406 Duo.
Old 08-08-2014, 07:11 AM
  #111
Team EAM
Trader Rating: 79 (100%+)
Set the cell count to Auto, Cut off voltage to 4.2 per cell (This is factory preset), 40 amp charge rate and thats it. ONLY Charge at high rates using the balance leads. NEVER charge at a high rate without using it set to balance. Your asking for trouble this way.
See my other answer below for discharge info.
J,
They use internal components or can use a battery. In order to achieve the maximum discharge rate you must hook up an external battery (Discharged one) to the other set of leads and do a regen discharge. It is simple and works awesome! The normal discharge is limited to about 20 amps on a 2S and 30 amps on a 1S battery.
EAMotorsports is offline
Old 08-08-2014, 08:07 AM
  #112
Mr RCTech's Avatar
You can charge at 40 amps.
But, why charge at 40 amps?
Puts too much heat into the cells to fast and makes the lipos swell.
If you go to the ICharger site they recommend no more than 30 amp charge.
As future lipos get better then you will be able to charge higher safely.
Mr RCTech is offline
Old 08-08-2014, 09:02 AM
  #113
Suspended
This is a good way to do it
This guy on facebook is selling these discharger resister banks made to plug into an Icharger and will discharge at 40 + amps https://www.facebook.com/raymond.mccoy.79?fref=ts
PFKAOG is offline
Old 08-08-2014, 05:26 PM
  #114
Josh-n-ya's Avatar
J,
Thanks EA
What battery's have you tried???
Interesting!
Old 08-08-2014, 06:37 PM
  #115
avs
avs's Avatar
hmm, that looks like it might be a good load for a slave motor in a dyno setup. anyone try that? seems like if it can pull down a high load on the battery then it could just as well absorb the output of a motor/generator combo?
avs is offline
Old 08-09-2014, 02:55 AM
  #116
daleburr's Avatar
Yes that works:
http://www.rctech.net/forum/11546052-post329.html
Good for testing cooling and making sure a motor hasn't gone off. Doesn't really tell the full story though, which is why I also created a flywheel dyno:
http://www.rctech.net/forum/11929704-post331.html
daleburr is offline
Old 08-09-2014, 10:23 AM
  #117
bukil's Avatar
Trader Rating: 39 (100%+)
I'm confused. Do you happen to have a pic of this? Or perhaps just a simple diagram? Thanks
bukil is offline
Old 08-09-2014, 03:11 PM
  #118
Josh-n-ya's Avatar
+1
Old 08-10-2014, 06:32 AM
  #119
speeddaddy's Avatar
Here is a YouTube Video
https://www.youtube.com/watch?v=L6Q_Ze6NC2g
speeddaddy is offline
Old 08-10-2014, 07:33 AM
  #120
As speedydad posted, you are essentially taking the energy from one channel (channel 1) and putting it to the other. You have to have some sort of load (or battery) on channel 2. For less than $30 USD, you could buy an Integy reactor, gut the electronics, and use it as a resistor to discharge into. There was some discussion of this on the icharger 308 thread.
I would guess even the old lightbulb dischargers from the NIMH days would work as well. And they might be cheap to make. I had one of these that broke, but it worked really well:
However, that resistor bank that PFKAOG posted looks really nice.
My preferred method to discharge without having to disrupt the use of your charger is to use a standalone discharger like this:
http://www.racersmeasurementsystems....r-Dumper-W.htm
I use a modified integy reactor (personally), as talked about here:
http://www.rctech.net/forum/radio-el...r-2s-lipo.html
JiuHaWong is offline
