Old 07-28-2014, 08:06 PM   #91
klaymon's Avatar
Trader Rating: 71 (100%+)
Just in case you were interested: http://www.tqracing.com/balance_&_power_cables.htm
Scroll to the bottom, item 2211.
klaymon is offline   Reply With Quote
Old 07-28-2014, 09:01 PM   #92
Regional Moderator
CarbonJoe's Avatar
Or, Tuning Haus offers pre-made cables
TUH1170 - Pro Charge Lead Set
http://www.tuninghaus.com/accessories.html
Available at http://www.tqrcracing.com/shop/produ....asp?p_id=7830
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 07-29-2014, 10:45 AM   #93
JayL's Avatar
Those are my favorite, nice thick wire, good bullets and 4/5mm ends for all batteries. Get these Pete
MOD: A800X LRP FlowX X22 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 07-31-2014, 11:53 PM   #94
Jerz616's Avatar
Trader Rating: 49 (100%+)
I got some form Nolan Porter oaf Porterhouse motorsports. Not sure if he's still making them, but they are awesome and were very well priced.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 08-01-2014, 04:10 AM   #95
theproffesor's Avatar
Trader Rating: 58 (100%+)
I like the look of the tuning hause ones, but just wish they were longer. Id like to see some 1m /3ft pre-made cables.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-01-2014, 12:33 PM   #96
CraigMBA's Avatar
Trader Rating: 22 (100%+)
The problem is if you double the length, you'll have to double the wire size for the same current, and the people using these chargers (not for bling) are charging at amps that need arc welding cable.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 08-01-2014, 02:23 PM   #97
I wanted longer than Tuning Haus as well. I made my own using TQ 2211 balance connectors, Tuning Haus 4mm/5mm combo bullet connectors and 12g Novak silicone wire in 600mm lengths. I charge 2S at 40 amps and the wire is just warm. Works great! The cable wrap can be picked up at Frys for cheap along with the heat shrink.
LAGuy is offline   Reply With Quote
Old 08-01-2014, 10:23 PM   #98
bshookup's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Potoczak View Post
Ok guys, I have the 308 charger. I want to make some charge Leads for 2s packs. I don't want to use the balance boards. Which pins on the balance plugs are the + - and balance pin??? Thanks.
Originally Posted by LasagnaCat View Post
From right to left... neg/bal/pos
You just made my day! I never even thought about getting rid of the balance board and uncluttering my pit space.
TEAM ASSOCIATED
REEDY
TEAM POWERS: www.teampowersusa.net/
bshookup is offline   Reply With Quote
Old 08-02-2014, 06:32 AM   #99
Potoczak's Avatar
Trader Rating: 112 (100%+)
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-03-2014, 11:53 AM   #100
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
So in using this cable you don't need to use the balancing board right? Just plug into the charger directly?
Josh-n-ya is offline   Reply With Quote
Old 08-03-2014, 12:45 PM   #101
Regional Moderator
CarbonJoe's Avatar
Yes. However, even though the cable uses only a 3 wire plug, do NOT plug it into the three wire jack in the charger. That is the temp sensor port. You use the right hand most three pins of the larger jack, which is the balancing port. It helps to use a Xacto blade to cut the left hand nub on top of the connector off, so that it fits easier into the port on the charger.
Old 08-03-2014, 05:56 PM   #102
Josh-n-ya's Avatar
cool thx
Old 08-04-2014, 04:24 PM   #103
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
On a loosely related side note... I also just plug the balance lead on my tx pack directly into the charger, then you just need a regular +/- charge lead for the tx pack and you're done.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 08-07-2014, 07:16 PM   #104
Josh-n-ya's Avatar
Just got mine today. It says the blue and red balancing plugs are for 1s and 2s. Which is which?
Old 08-07-2014, 08:34 PM   #105
Regional Moderator
CarbonJoe's Avatar
When charging a 2s, the red balancing lead gets plugged into the 2mm tube on the red bullet plug, and the blue 2mm balancing wire plugs into the balancing port on the battery.
For a 1s pack, the blue balancing wire goes in the 2mm tube on the red bullet plug, and the red wire just hangs free.
