Old 07-23-2014, 05:38 PM   #76
theproffesor's Avatar
Trader Rating: 58 (100%+)
Im still confused it doesnt answer my question of the numbers not adding up. I have gotten brand new packs and tested them at 3.8v per cell at 3ohms per cell on my icharger 206b. Ive heard of others getting into the 1.5 - 2 ohms per cell with the same size pack.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is online now   Reply With Quote
Old 07-23-2014, 05:51 PM   #77
Trader Rating: 132 (100%+)
Well, most packs after 10 or so runs will decrease in IR. The first two cycles are generally "throw away" cyclings. Meaning the numbers are the highest they will be. Temperature has a good deal to do with the pack's IR. TO a point the warmer a pack is the lower the IR. Maybe like 100 degrees or something is ideal for the pack. Also with most manufacturers the batteries vary slightly and by slightly i mean too much. Some may be around 1.5 and others are 3 depends on the company and who they are buying from. Hope this answers the questions.
thecaptain is offline   Reply With Quote
Old 07-23-2014, 08:08 PM   #78
Jerz616's Avatar
Trader Rating: 49 (100%+)
I use ORCA packs that have had roughly the same IR since the day I got them. I have a 6000 pack that I run in mod sedan and its over a year old and has well over 100+ charge/discharges on it and it is still at 1.3 per cell and gets as low as .9 per cell throughout the day depending on how much its ran. My 7500 packs are about 6 months old ran in 17.5/13.5 sedan and they are usually about 1.1 per cell. They have been as low as .7 per cell. This is how they have been since the day I bought them fro EA. I even have a 7200 pack that is well over 1 1/2 yrs old and is puffed( i left it fully charged for over 2 weeks because I forgot about it after racing one day), and this pack is still good at 1.5 per cell and prob 300+ charges on it. All of these have been charged solely on my 308 at 20+ amps every time. I believe the 308/406/4010 keeps the the packs very healthy as long as you keep them storage charged when not used, and the quality of the pack is a huge part of it.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 07-24-2014, 04:39 AM   #79
tc3team's Avatar
Originally Posted by speeddaddy View Post
Don't worry about what charger you have. You could charge your battery on a 500.00 charger and the Big Dog at your track could charge his battery on a 20.00 charger and he will still go out and still whip your butt. It's all about driving and practice,practice,practice
+1
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-24-2014, 07:18 AM   #80
stro3579's Avatar
Trader Rating: 20 (100%+)
Originally Posted by EAMotorsports View Post
I bought the first I charger 4010 duo sold in the US back in Oct 2012. When they first came out. My charger has never been calibrated and has its ending voltage has never changed. Its been dead accurate since I got it and I can promise Ive charged more batteries on it than most people on here combined since I use it for cycling brand new packs when I get shipments in to verify their quality.
I have since bought a 308 and just recently a 406 just because they are smaller to travel with. The 308 is more than enough charger for most people and can be bought for under 250.00 or less. No special power supply needed as if your charging at 30 amps it only pulls about 18 amps off of your power supply on 2S and 12 amps on 1S. I routinely charge at 25 and 25 on both sides on a 40 amp power supply with zero issues.
To me it is the best charger out there as far as accuracy and reliability.
EA
What power supply are you using with your 308 for traveling?
stro3579 is offline   Reply With Quote
Old 07-24-2014, 08:58 AM   #81
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
A 12v converted computer power supply. weighs 3lbs.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-24-2014, 10:12 AM   #82
snuvet75's Avatar
Trader Rating: 16 (94%+)
How do you guys prevent the battery packs from puffing?
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 07-24-2014, 11:03 AM   #83
Mr RCTech's Avatar
Never charge over 30 amps.
Move expensive higher C rated lipos have a thicker copper that disperse the heat faster to a point of 30 amps.
As batteries get better over time you might be able to charge higher.
Too much heat will cause lipo pack to swell.
Mr RCTech is offline   Reply With Quote
Old 07-24-2014, 11:41 AM   #84
A quality lipo after cycling say 10 times or so shouldnt puff, if it isnt abused. Im not sure if a touring can abuse a good quality lipo even with like a 4.5t motor with boost. However a 4x4 short course is another story most batteries will puff in one of those due to the high discharge rate, i've taken one out that was flat in the beginning of the race and at the end of the race it was 100 deg externally and puffed.
Old 07-24-2014, 11:49 AM   #85
snuvet75's Avatar
Then in another way, how do you prevent the battery temp from rising. Obviously controlling ESC and motor temp is one thing. Any other I should be aware of?
Old 07-28-2014, 04:52 PM   #86
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
Have you run that pack against a different pack that has a (much) higher IR? If you run a pack that's at .9 per cell, and then run a pack that's 3 per cell (with all other things being equal...) how much time on the clock does that translate to? Tenths, hundredths, thousandths per lap? How much actual time are we chasing in the low IR hunt?
If you can run a heat with a good handling car, not touch or hit ANYthing, and turn a bunch of laps with an average within a tenth or two for your top ten or twenty (or more) laps... is a good pack going to be a night and day difference?
How much would battery condition affect your gearing? The never-ending discussion on race day seems to be FDR... how much would your gearing change (to get the same lap times) on two identical cars if one was running a good pack and other an old tired pack, if at all? Just trying to make this into a tangible measurement somehow, and not just people being OCD over IR and measurements because it's something you CAN measure.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 07-28-2014, 05:25 PM   #87
Jerz616's Avatar
I don't really rely on the IR for anything other then how healthy the pack is. When your running mod sedan you have so much power on tap that your not going to really see much difference. When I was running stock I never did any comparisons on lap times, but I could feel the difference in the punch from other batteries and the packs didn't fade off much at all after 6 min.
Ryan Gracey
XRAY XB8'14
Old 07-28-2014, 06:21 PM   #88
Potoczak's Avatar
Trader Rating: 112 (100%+)
Ok guys, I have the 308 charger. I want to make some charge Leads for 2s packs. I don't want to use the balance boards. Which pins on the balance plugs are the + - and balance pin??? Thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-28-2014, 06:31 PM   #89
LasagnaCat's Avatar
From right to left... neg/bal/pos
Old 07-28-2014, 06:34 PM   #90
Potoczak's Avatar
Thank you!!!!!!!
Pete Potoczak
