Speedmerchant Roadkill 10 235mm Pro10 Pancar >
Like Tree64Likes
Old 10-04-2017, 11:43 AM
  #676
Thanks Toady. Just a couple of ?'s, what size are you truing the tires down? And how is it with the 17.5 this year?
Thanks again.
RoyU is offline
Old 10-04-2017, 11:57 AM
  #677
TOADYY's Avatar
Thanks again.
53mm rear and 52.5mm front.
17.5 for me is easier to drive than 13.5 from last year. We have a total of 12 Pro 10. You can catch the live action on liverc.com , Q1 will be up in about 20min for Pro 10.
Taz_S and jetnjme like this.
TOADYY is offline
Old 10-04-2017, 12:33 PM
  #678
TOADYY's Avatar
What is the weight of the "Blue Spooge" tube lube?
Green = light
Red = medium
Blue = heavy
According to Bruce (just asked him) the manufacturer of the spooge will not tell what the actual weight is for each. All the 235 cars use blue.
TOADYY is offline
Old 10-04-2017, 07:19 PM
  #679
TOADYY's Avatar
Default 2017 IIC Pro 10
L to R Andrew Mowery, Donny Lia and Steve Boice
Taz_S, liljohn1064 and DMD like this.
TOADYY is offline
Old 10-04-2017, 08:57 PM
  #680
Nice! I wish I was there. Oh well, maybe next year!
RoyU is offline
Old 10-05-2017, 11:30 PM
  #681
What's the gear ratio/fdr that being used at the IIC?
RoyU is offline
Old 10-06-2017, 10:15 AM
  #682
TOADYY's Avatar
My rollout is at 50
TOADYY is offline
Old 10-14-2017, 10:25 PM
  #683
TOADYY's Avatar
2017 IIC Pro 10
https://www.youtube.com/watch?v=8CXTxuOutXI
DMD likes this.
TOADYY is offline
Old 10-15-2017, 12:57 AM
  #684
rc_square24's Avatar
Hi, I have some questions on Pro10 tires and wheels as I'm interested in getting one of these cars.
Are the front and rear wheels standard like they are with 12th scale? How about tires? I don't see much Pro10 tires available except for WGT which I believe is narrower.
Thanks!
rc_square24 is offline
Old 10-15-2017, 11:44 AM
  #685
TOADYY's Avatar
Thanks!
Yes, the front and rear wheels are standard width and size. The WGT Spec tires are standard size.
WGT chassis is narrower than Pro 10.
WGT width = 200mm
Pro 10 width = 235mm
Here is where you can buy Pro 10 tires and parts.
1/10 Foam Tires
https://shop.stormerhobbies.com/category-s/1114.htm
TOADYY is offline
Old 10-16-2017, 08:25 AM
  #686
Trader Rating: 28 (100%+)
Set-up from the IIC.
This car is amazingly easy to drive.
Its literally the most fun you can have driving an RC car...
File Type: pdf
Bigdaddyswank is offline
Old 10-17-2017, 01:03 PM
  #687
MrHistory's Avatar
Hey guys
Curious whats what with Donny's car. Not sure what comes in the kit and what is aftermarket. Trying to sort out what the kit includes, if its the car in photo...
1. Is Donny using IRS Offset D-Ring Axle and Hubs Kit - BLUE?
2. Will the KOP30127 - KO Propo RSx3-12 Digital Mini Servo (World Spec) work?
3. What are the best pivot balls / links for steering?
4. Servo Saver?
MrHistory is offline
Old 10-17-2017, 01:38 PM
  #688
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by MrHistory
Hey guys
2. Are there Speedmerchant Options needed from website?
3. Will the KOP30127 - KO Propo RSx3-12 Digital Mini Servo (World Spec) work?
4. What are the best pivot balls / links for steering?
5. Servo Saver?
6. Are the new Tweak braces / top plates / Damper tubes included? this is confusing on the website news page.
I believe you have a picture of the latest kit. The axle is IRS and for some reason he's using the blue outer hubs. I see a lot of blue on his car. There are no special options shown in the picture. What you see is what your get less the electronics. The RSX-12 servo works perfectly. Associated 4-40 type hardware, so pick your favorite ballcups. Servo saver looks like a Kimbrough medium. Again, Everything you see less electronics is in the box.
Pro10noob likes this.
liljohn1064 is offline
Old 10-17-2017, 04:18 PM
  #689
MrHistory's Avatar
Thanks John!
Old 10-17-2017, 04:32 PM
  #690
TOADYY's Avatar
Please note the pic above will be the "Carpet Version" when it's available.
TOADYY is offline
