Schumacher Mi5 evo
All the info for the Evo is under the regular MI5 thread. No real need for a new thread.
Good move...I have just built mine and running 21.5 open so running 44/18 pinion which just fits and gives me 4.4 fdr at club level but have champs coming up that require us to run 21.5 blinky so be interesting to compare setups etc.
I have got the grey belts, blinky mount, front dcjs, 2 degree rear arms and rest is manuel set up...first run at club level next sunday.
ok..thats running a low fdr at 3.82?..I am aiming for 3 or below but our track has a long straight.
Thanks.
I should mention that these will give low bodies (although are legal to 115mm on a 10mm block), so you will need to trim quite a bit of the splitter and sides back. I have about 4-5mm of splitter on both my Speed6 and LTC-R.
Easiest way to trim them back is mount the shell up on the car, with wheels and tyres, and battery, and set to 5mm rideheight on a setup board. Then run a Sharpie pen around the board, holding it flat down, drawing a new cut line on the body. Then cut to the line
HiH
Ed
HiH
Ed
Another blog post detailing first few meetings with the evo... becoming more impressed with how the car is working, a definite step on from the 5.
(Also attached some setups to the post)
http://www.thard.co.uk/mi5-evo-update/
