Old 08-28-2005, 03:59 AM   #1
Default TB02 vs. TA05
Which is the better car for racing/drifting up and down the street on weekends, the Tamiya TB02, or the TA05? Thanks.
Seatbelt is offline   Reply With Quote
Old 08-28-2005, 04:05 AM   #2
Skitee's Avatar
The TB02 should be better for drifting because it has a shaft driven drivetrain, shaft drive does give more immediate throttle response than belt drive which is a definate advantage in drifting. That said you can get really good drift from a belt drive car too as I have with my TA03 and TA04, as far as general street and aprking lot bashing goes both cars would do fine because they have a tub chassis. My pick would have to be the TA05 simply because maintenance is far easier to do than on a TB02.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-28-2005, 04:24 AM   #3
ford_racing's Avatar
Send a message via MSN to ford_racing
the TA05 has my vote as well,
its a newer chassis and better for racing if you decide you want to do that aswell as drift
both cars will be as capable as each other at drifting its just down to setup which there are lots of guys trying out different things with the ta05 currently and they will be able to help you lots
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 08-28-2005, 06:51 AM   #4
In what ways is the TA05 easier to maintain than the TB02?
Old 08-28-2005, 09:24 AM   #5
Send a message via ICQ to rcnewb2004
The ta05 is a belt drive. So at least to begin, no fusing around w/ stripping gears. I had my belts for 1.5 yrs now, and they run fine still!
rcnewb2004 is offline   Reply With Quote
Old 08-28-2005, 10:03 AM   #6
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I have both a TB-02 and a TA-05, as well as a couple Surikarns...the shaft cars are hands-down easier to work on. Set up the gearboxes right ONCE and you're done forever. The TA-05 is easier to work on than my old Pro-2 HPI (because the diffs come out the top), but it's still a pain compared to the shaft cars (TB-02 and EVO-III).
Turbo Joe is offline   Reply With Quote
Old 08-28-2005, 12:14 PM   #7
Thumbs up
The TA05 is only my second on-road car, but I am very happy with it. I also have a TT-01 with nearly all tune options. It runs very smooth and is very responsive to setting changes. So easy to work with.
I drove the TA05 on an indoor cirquit for the first time yesterday. It was easy to find a good setup for the first few runs. With some more time I think it can be a nice racer.
Next to that it is also sturdy and can take some punishment. The tub is very strong.
F1mechanic is offline   Reply With Quote
Old 08-31-2005, 01:56 AM   #8
Which one would be the most competitive?
Old 08-31-2005, 02:09 AM   #9
When any relatively new car is tuned optimally, the racer is the most competitive. The cars are relatively the same with all hop-ups.
But my vote goes to the ta05, simply, less fuss, replacing belts in most cases are cheaper than gears, and the belts almost never need replacing.
Old 08-31-2005, 04:25 AM   #10
I hope a TA05 have a big edge over TB02.
In my only race in TCS GT2, with my old stock TB01, I was faster then many TB02.
Going to make the 2005/2006 local TCS with a TA05, and since it is a new car, I hope to have an advantage over the 80% of people still with a old car like TA04 and TB02 ...
e_lm_70
P.S: Motor position, trasmission efficiency and weight should be in big favor for TA05 ... considering that a Jap company is planing to make a carbon chassis for race in a world event ... I guess the TA05 has even more potential the the 415 !
e_lm_70 is offline   Reply With Quote
Old 08-31-2005, 04:33 AM   #11
i wouldn't quite go that far, sure the TA05 is good for stock, but in mod the 415 would win hands down
you're pretty much saying why run mod with a evo4/415 when there is a perfectly good tb02/ta05
the tb/ta simply flex too much to handle the low turn motors required in mod although in stock they do quite well, TCS is certainly within these limits so it should be very interesting to se how they do
ARC R11
Yokomo YRF001
AE B5m
Old 08-31-2005, 12:02 PM   #12
Ghostfit's Avatar
e_lm_70
The TA05 isn't gonna automatically make you faster than 80% of the other racers. You need track practice to achieve that !
....and I would'nt go that far ! ....depending on the track and setup, the TA05 has got more steering and corner speed than the 415. The people in Japan seems to believe strongly in the 05, plus in the next few months, you'll see a tsunami of TA05 hopups from just about every Japanese (and some HK too) aftermarket company! ....I can't wait to see what the real TAMIYA TRF416 will be like !
Ghostfit is offline   Reply With Quote
Old 09-01-2005, 02:26 AM   #13
Sure man ...
But if with a TB01 I can be faster then many TB02 ... I hope taht with a TA05 I should have better iron then the competition with TA04 and TB02 ... so I hope with a TA05 to be able to be close to the top guys ...
e_lm_70
Old 09-01-2005, 02:43 AM   #14
Ghostfit's Avatar
Sure man ...
e_lm_70
Ahh ! ...I see your point ! I'm sure you're be able to run with the top dogs with the TA05 .....just dun be afriad to run "Stiffer" springs
wtb: f103gt f201 ta05 tb02 J-PaP Australia Wanted to Buy 0 01-05-2008 09:26 PM
tamiya tt01 ta04 ta05 tb02 willabong Australia Wanted to Buy 2 08-27-2006 09:37 PM
Tamiya TB02 vs TA05 for TCS and club racing. SA22C'ya Electric On-Road 16 04-26-2006 09:37 AM
Straight trade TB02 with TA05 charlie_b R/C Items: For Sale/Trade 2 09-18-2005 08:13 PM
Tamiya TA05 and TB02. N15M0 Singapore R/C Racers 23 08-05-2005 10:23 AM
