Old 10-05-2001, 07:47 AM   #1
Default airbrush air supply
Has anyone here heard of using an inner tube as a pressurized air supply? Does it produce enough pressure to power the paint through? We were told about this once but I'm skeptical. Thanks.
coolrcdad is offline   Reply With Quote
Old 10-05-2001, 08:43 AM   #2
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Yeah, Ive heard of this. Badger actually makes an adapter to do this. The problem is that you lose pressure steadily as you paint.
Jack Smash is offline   Reply With Quote
Old 10-05-2001, 12:18 PM   #3
TurnNBurn's Avatar
What Jack said, and you have to worry about moisture accumulating inside the tire. You would need some kind of moisture trap.
TurnNBurn is offline   Reply With Quote
Old 10-07-2001, 11:29 PM   #4
Send a message via ICQ to JesseT
An inner tube is not sufficient! You must have a whole tire and wheel. Anyhow, this is not a good choice. Like mentioned before the pressure drops steadily all the time and lasts only for a moment. It's also dangerous to pump the tire to too high a pressure while trying to gain more time. I would suggest a compressor. If it's too expensive, but your somewhat handy, try one from an old fridge.
BR/ JesseT
JesseT is offline   Reply With Quote
Old 10-08-2001, 12:50 AM   #5
Trips's Avatar
Trader Rating: 16 (100%+)
Probably the best bang for the buck in an airbrush compressor right now is the Campbell-Hausfeld Quiet-Air compressor. It comes with a gauge and regulator on it, and sells at WalMart for around $99.
I was on a very tight budget when I got mine... I checked the local pawn shops and found mine for $25, and I've been using it happily for over a year now.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-08-2001, 02:33 AM   #6
R/C Tech Founder
R/C Tech Charter Subscriber
I have that same Campbell-Hausfield compressor, it works great. The only addon you might consider getting to it is the moisture trap/air filter, which costs another $12 or so. It's optional though, and still works well without it.
I use that compressor for everything, even charge it and take it to the outdoor track with me to hose my car with air when it gets dirty.
futureal is offline   Reply With Quote
Old 10-09-2001, 02:37 PM   #7
seaball's Avatar
Send a message via Yahoo to seaball
i've been using a compressed nitrogen tank. it's a 2000 psi tank, and i've got a regualtor on it. works great. it's like $7 to fill and lasts a few bodies. i don't remember what it was for the tank. lss than 100 though, and it's silent.
seaball is offline   Reply With Quote
WTB: Airbrush NitroMaxx3.3 R/C Items: Wanted to Buy 6 11-10-2007 09:20 PM
GT7, 10L4, Integy Lathe, CE Power Supply, Airbrush Compressor andrewdoherty R/C Items: For Sale/Trade 31 06-22-2007 09:34 AM
Looking to by a Complete airbrush system... (gravity airbrush) DjZ0rKy R/C Items: Wanted to Buy 2 08-14-2006 07:55 PM
Airbrush FS/FT racenit R/C Items: For Sale/Trade 1 01-20-2006 08:46 PM
airbrush qusetions , requesting airbrush pros' xaznriceracerx Painting, Designs, Graphics and Photography 2 08-29-2003 12:33 PM
