Old 07-05-2014, 08:26 AM   #46
I painted a LTC-r LW today.
87g with thick wing, head and tail lights only and minimal paint.
frozenpod is offline   Reply With Quote
Old 07-05-2014, 08:42 AM   #47
Originally Posted by thecaptain View Post
I depends how many stickers and paint you cake on your body. If you paint them lightly and only use a couple stickers you can achieve 65 gram bodies.
Ie: just like you see Rheinard et all running in quali typically - single colour, minimal sponsors, paint so thin it's translucent.
cplus is offline   Reply With Quote
Old 07-05-2014, 12:08 PM   #48
Suspended
1380g - 1170g equals 210grams........ The $75 thunderpower 3300mah 65C weighs 208grams and will be perfect for your case.... Any heavier lipo packs will be detrimental to your car's performance...Try to lighten your car as much as possible to make room for heavier packs...
Originally Posted by TB03Racer09 View Post
My car weighs in at 1170g without a battery, would using a 300g battery still be wise (orca 6200mah 90c). I don't need the most competitive car, but I would still like to be able to compete
bertrandsv87 is offline   Reply With Quote
Old 07-05-2014, 06:34 PM   #49
gooba's Avatar
I run a 4200 65c shorty in my tc and wouldn't change it unless I was forced. I likel the light weight and ability to move it around to help weight distribution. As far as weight you also have too see if your track has a minimum weight. Both tracks I race at have a minimum. One is 1380 grams the other is 1400
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 07-05-2014, 10:31 PM   #50
TB03Racer09's Avatar
I think I need to get a shorty and a standard size and start experimenting on the track and see whats better. I calculated the shorty LiPo+ titanium screws will get me to 1400g, which is quite respectable
Reason for a shorty over a full size lightweight pack is that I can move some of the electronics to the battery side
TB03Racer09 is offline   Reply With Quote
Old 07-06-2014, 12:17 AM   #51
I predict the full size will prevail in the end cause the drop off will be slight if any. The shorty may seem to be fast in the beginning but will drop off much more severe.
Minh Nguyen
[Maclan Racing] [Xpert Servos]
trigger is offline   Reply With Quote
Old 07-06-2014, 02:01 AM   #52
gooba's Avatar
I've never noticed any drop off over a 5 minute run with a shorty I could run 2 qualifiers easily if I wanted. I run just as much timing and run just as hard as everyone else and I just don't seem to use up all my battery over a 5 min race
Old 07-06-2014, 06:39 AM   #53
Trader Rating: 132 (100%+)
Well then don't ever get rid of that battery. First one I've heard of that doesn't drop off. Yes you could easily run a pack two times. However the 2nd time it wouldn't be as strong and have an extreme drop off after a few minutes.
thecaptain is offline   Reply With Quote
Old 07-06-2014, 08:10 AM   #54
Suspended
Smile
Voltage dropoff is negligable in 17.5t racing........ The top drivers use to race 5 minute mains with 7t brushed motors and 3300 nimh packs, so why shouldn't we race 17.5t with a 3300mah lipo ??? Simple economics.....
Old 07-06-2014, 08:58 AM   #55
d16dcoe45's Avatar
EVERYBODY who raced high level mod used 3300 packs with those 6 & 7 turn motors so they were on a level playing field. My guess is that the voltage/speed difference from start to finish was HUGE but accepted because every car dealt with the same drop-off.
I can see if you have a heavy tub-chassis car wanting to use a shorty or low capacity lipo, but any modern TC with a LW shell can usually make 1380g using a 7500 or 7600 lipo, even if its a minor voltage advantage its still there and it will help in a limited power class.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 07-06-2014, 09:02 AM   #56
bakoo's Avatar
I have no problem noticing voltage dropoff on a 13.5T, it manifests as less overall punch and lower top speed on the straights.
Edit: If I'm not mistaken, a mere 0.1 V drop equals roughly 300 rpms off the top end of an unloaded Speed Passion 13.5T brushless motor, so it's not just in my head either
bakoo is offline   Reply With Quote
Old 07-06-2014, 10:40 AM   #57
They have the motor to negate the voltage drop off. It's noticeable just not big deal. Same thing happens with like 4x4 short course. They have the motor you can only really see the drop off towards the end of the race. Or even after that. With 17.5 after the first minute or two there's difference in lap times.
Old 07-06-2014, 12:42 PM   #58
DesertRat's Avatar
First rule of RC car racing: Don't listen to Bert.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 07-06-2014, 02:38 PM   #59
gooba's Avatar
Maybe I'm not as in tune as some of you guys but I just don't notice any drop off. I run shorty for the finer weight placement. my tub car is fairly light so I use full size packs to make weight in vta not to combat drop off
Old 07-06-2014, 11:38 PM   #60
Suspended
Smile
Specially when BERT's faster than you....lol........
