Best battery for 17.5t blinky >
Old 07-28-2014, 07:18 PM
  #136
The graphene supercapacitors will stop all lipo voltage drop from high current draws when you hit the throttle, but they need to be used with the lipo packs, and not try to replace them... No way a lipo pack is going to compete against a combo of graphene supercapacitor and another lipo pack of the same brand and size.... Remember, the supercapacitor is only there to stop voltage sag for a second or so, not to run the car for six minutes, and the new graphene supercapacitors have way less resistance than lipos..All that's need is a difference of 0.5 volts for a second after each corner to make a huge difference.... It won't be long before we start using them, if some are not already secretly using them...lol.....
Originally Posted by frozenpod View Post
The current lipos are excellent but the next evolution for RC might be the new super caps (currently under development). They can be charged in seconds and have well over 10,000 of cycles.
The current readily available high capacity super capacitors have a lower energy density and similar IR of the current lipos. Not a huge amount to gain by using them.
bertrandsv87 is offline
Old 07-28-2014, 07:35 PM
  #137
Maybe the potential is certainly there but until there is a retailed capacitor with a full datasheet and we test them on the track we wont know.
frozenpod is offline
Old 07-28-2014, 07:40 PM
  #138
Originally Posted by thecaptain View Post
that would be very neat to see a battery that can be used in our cars like that. I bet theyd be SUPER light. Like 100 grams if that, and would last the entire race and be much smaller than the traditional stick lipo. Which would allow for radically new chassis lay outs! Or we could put them on our esc... and replace the standard caps
I don't think they will offer the energy density of Lipo and the voltage discharge curve is not as good when compared with chemical storage ie lipo.
They are currently being explored for use in conjunction with Lithium cells for electric vehicles.
Pretty much what bert is suggesting.
Old 07-28-2014, 07:44 PM
  #139
Correct, but I feel some racers will have access to the product long before we do...... Hopefully race directors will be able to level the playing field.... There is a guy using a similar product on airplanes mostly. Warthog power systems is his company, and if he gets access to those graphene supercapacitors, he can change the RC tc racing world for good....
Old 01-06-2021, 07:02 PM
  #140
DJEckart's Avatar
Originally Posted by oeoeo327 View Post
The one situation where additional weight would be counterproductive is when there's no minimum weight specified. Most Lipo-ready cars need additional ballast to meet weight requirements if the rules specify a minimum weight; in these situations adding capacity also assists in bring the chassis up to your club's racing standards. If balance becomes an issue, work towards moving the battery closer to the centerline of the chassis.
Well, that's true, but I'd rather have a lower weight base to start with and then add ballast wherever I want to - not within the limitations of the battery tray mounting system. the key is where you put the weight, and to make the car/truck carry more corner speed, and not necessarily get the max acceleration.
DJEckart is offline
Old 01-06-2021, 07:15 PM
  #141
dawgmeat's Avatar
IP Lipos
dawgmeat is offline
Old 01-07-2021, 06:45 PM
  #142
Motiv has some really good cells with very low resistance
17.5 blinky is a power to weight game.
A-Ko is offline
