Old 09-23-2002, 09:08 PM   #1
MX3
Default yokomo charger
would anyone knows where i could find info on the yokomo BMS and BCS charger???i cant seems to find any info in yokomousa homepage
MX3 is offline   Reply With Quote
Old 09-23-2002, 10:23 PM   #2
TRF414M's Avatar
What kind of information that you need to know.
This is the list of chargers from Yokomo
Yokomo BMS (similar to GM-VIS commander, charge, discharge, cycle)
Yokomo BCS Double (just 2 chargers in one case, no discharge)
Yokomo BCS-S (Smaller version of the charger, no discharge capability) It uses similar case of their motor checker
There are three charge modes:
Yokomo Charge
Peak Charge
Temp. Charge
TRF414M is offline   Reply With Quote
Old 09-23-2002, 10:27 PM   #3
Diva's Avatar
Send a message via Yahoo to Diva
And BMS has dual ventilation fans which provide excellent cooling effect. I used it to recycle my packs and it never got heat, not even warm.
Diva is offline   Reply With Quote
Old 09-23-2002, 10:28 PM   #4
MX3
i just need to know their charging rate(in amp)/discharge rate(adjustable?)/threshold peak detect??(adjustable??)/what are shown on the display/what's the mininum input supply do they need??
Old 09-23-2002, 10:38 PM   #5
Diva's Avatar
Wink
I think its charging rate ranges from 0.2-9.9A. Discharge rate ranges from 0.2-20A. Threshold adjustable (can't remember the range). 12V DC supply
Hope it helps.
Old 09-24-2002, 02:49 AM   #6
TRF414M's Avatar
I prefer LRP instead because they have lifetime warranty. I used to have the BCS double and BMS charger.
BMS charger is just too heavy.
BCS Double have some minor problem
BCS-S (Don't want to try it anymore)
Old 09-24-2002, 02:00 PM   #7
What does the BMS cost at most US hobby shops? I'm not looking to buy a charger right now, just curious is all.
JeffC is offline   Reply With Quote
Old 09-24-2002, 09:06 PM   #8
Pyramid's Avatar
USD250 should be good figure.
Anyway, like other people said, BCS has a minor problem such as hang, error, etc. I personally think that either BCS/BMS will shorten your battery lifes. But hey, you will never know until you experience with one.
Pyramid is offline   Reply With Quote
Yokomo BCS Charger TwinKays R/C Items: For Sale/Trade 0 08-13-2007 03:10 AM
Yokomo Charger YZ-110 Pro TENCHO Electric On-Road 3 12-14-2005 04:27 PM
Yokomo BCS-D Charger yokcgmracer R/C Items: Wanted to Buy 3 01-02-2005 10:01 AM
FS: Yokomo BCS-S Charger micros_rock R/C Items: For Sale/Trade 13 08-24-2004 05:54 PM
Yokomo BCS charger coolrcdad R/C Items: For Sale/Trade 10 01-26-2004 07:00 PM
