Old 08-25-2005, 10:24 PM   #1
LosiSuperTruck's Avatar
Trader Rating: 18 (100%+)
Default Which size pinion to use?
Hi All,
I have a TC4 with a 100 tooth spur gear. Which size pinion should I use with the 27T Monstor Stock Pro and 19T Chameleon Pro 2? I also bought a 72T and 68T spur. But the 100T is installed.
A general Idea would be good as I know track conditions play a role, but I need to know say 3 pinions I should carry for each motor.
I'd say the track is roughly 150'x50', it is a mix between technical and speed. There is one long straight along the back probably the entire 150' that goes into a long sweeping turn that probably goes 50' until it bring you back in the other direction. This is an extremely fast part of the track.
LosiSuperTruck is offline   Reply With Quote
Old 08-26-2005, 03:09 AM   #2
mike ivy's Avatar
Trader Rating: 50 (100%+)
For the Monster Stock Pro I would use any where from 35 up to a 38 tooth pinion 64p and for the 19t I would use any where from a 34 up to a 37 tooth pinion 64p just make some practice runs for both motors and see how they are on the track hope this helps
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 08-26-2005, 03:21 AM   #3
Birky's Avatar
I would talk to some of the drivers at the track you want to race at. Ask them what rollout (if running foams) or gear ratio they are running and this should be a reasonable starting point.
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 08-26-2005, 06:44 AM   #4
I am asking here because I won't have a chance to buy any once at the track. This is the only race at this track this year, so I can't really bring more next time
Old 08-26-2005, 06:51 AM   #5
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
here.....
http://www.gearchart.com/index.cfm?f...n=chart.create
Print out your car and spur
Try to get your ratio in the neighborhood on 7.0-7.2
that should be the best starting point.
-Shookie <><
for 100t spur a 35t pinion is right there in that area.
Glad to be a help
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-26-2005, 07:05 AM   #6
ooliganRC's Avatar
Send a message via MSN to ooliganRC
bit like asking
what colour t-shirt should i wear?
everybodies opinion will be different......
gearing takes effect in many ways based on the following:
track- technical or flowing
weather - hot or cold
experience - you good average or bad
battery - new old 33oo 3700 3800
tyres- new old conditionl
driving style - throttle jammer or smooth
variables that can only be sorted on the day...
suggest you buy imo 48 pitch 27 - 32 for a 68/69 spur
or
64 pitch 37 - 42 on a 80/82 spur
good luck
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 08-26-2005, 07:17 AM   #7
Nice chart shookie did you make this?....nicely done
I know this is a stupid question, but the higher the gear ratio the more top end you will have, with less acceleration? Or do I have it backwards?
Thanks All
Old 08-26-2005, 07:25 AM   #8
Another question....I bought the car and it had a 100T spur on it, I think stock should be 72T for the TC4. What is the advantage of a 100T over 72T? From my understanding, I would still need to change the pinion to get in the 7.0-7.2 gear ratio. So what is the difference?
Thanks, and I appreciate you all answering a newbie's questions
Old 08-26-2005, 07:43 AM   #9
Although flatering...No I didn't make that...I am blessed to have such a great site out there for me to have such an easy access to such information...now as far as which spur to use...It is up to you.
I like a bigger spur because I run 19T also so I need the larger spur to get my ratios right for it also..
FOr you, you will be well served with a 72...I used that in stock for quite some time when I first got into TC...
Hope this helps,
-Shookie <><
Thanks All
Old 11-06-2005, 06:48 PM   #10
nwilcox88's Avatar
Okay.. I am a offraod racer trying to run onroad this winter on the carpet. I have a TC4, in offraod we know the raio of the trans. What is it in the TC4? And what is this about getting a ratio of 7.0-7.2 is that the Spur Gear divided by the Pinion Gear?
nwilcox88 is offline   Reply With Quote
Old 11-08-2005, 12:07 AM   #11
Birky's Avatar
Originally Posted by mi2dude
bit like asking
Black, cause when you wipe your hands on your shirt, the grease, oil, dirt etc, doesn't show up.
Pinion size for 7.5brushless on a b4... zapmike Electric Off-Road 14 12-02-2007 01:07 PM
What Size Pinion Wreckless_Daz Electric On-Road 1 08-16-2007 04:15 AM
TC4 Pinion size for LRP 4 Star ioxqq Electric On-Road 1 08-28-2006 10:12 AM
roll 0ut& pinion size MOJO Rookie Zone 2 11-29-2005 06:35 PM
what size pinion? ballou Electric Off-Road 3 09-26-2004 02:43 AM
