Old 06-21-2014, 03:43 PM   #1
Default Sakura D3 problems
I have had a sprint 2 drift for about a year now and decided to upgrade. I was always fond of the Sakura kit and finally got to order it and it was fun to build and seems awesome. I am new to the CS world so bare with me, but im having some issues. I am running a speed passion combo 3.0 10.5T system. I ran the car for the first time today and slow it works fine but when i get close to full throttle the front wheels shake realllll bad. The main drive belt flapps real bad and wheels bounce up and down, anyone else had these problems?
Sir_Drifts_Alot is offline   Reply With Quote
Old 06-21-2014, 03:53 PM   #2
Also the motor and esc combo do i need to hook up the sensor wire or run sensorless?
Old 06-21-2014, 04:02 PM   #3
ZiG-87's Avatar
For drifting it's all about control, so yes you want to run the sensor wire. As for the wheels shaking, have you checked the diff and axles? It sounds like something wasn't put together quite right and is binding at certain points in the rotation, or something along those lines..
Also 'alot' isn't a work in the context you're using it in, it should be 'a lot'.
ZiG-87 is offline   Reply With Quote
Old 06-21-2014, 04:21 PM   #4
Thanks for correcting the name, i do know that, but i had reached the limit of characters, and i didnt care its just a name so dont be a jerk.
I have checked everything and its all tight, i wondered if i got to big of a belt because i have read they mess up on the belts for the kit often.
Old 07-06-2014, 07:52 AM   #5
Figured it out, the main belt is skipping teeth on the rear pulley and making it twitch, it is the 519 should i get a 517? Also the front wheel chatter is becasue the stock cvd's cant handle that much of a angle, is that correct as well?
Old 07-06-2014, 08:50 AM   #6
ThePanda's Avatar
Trader Rating: 65 (100%+)
Unless you go to double jointed shafts, all types of shafts will shake. I don't reccomend pointing a bunch of money into that car through, when in the end you could just save that money to get a more capable chassis.
ThePanda is offline   Reply With Quote
Old 07-06-2014, 01:18 PM   #7
Well i just went from the sprint 2 and have wanted this chassis for a while. Ive already got alot into it to get it goin so another 40 bucks for shafts and another belt wont be to bad really.
Old 07-06-2014, 05:07 PM   #8
ThePanda's Avatar
New dcj shafts will really help with the shaking.
Old 07-06-2014, 07:06 PM   #9
Thanks man, im gonna order some!
Old 07-06-2014, 09:14 PM   #10
for the skipped belt, i did have the same problems and i changed to the new one. and IMHO don't push the throttle suddenly just keep it smooth and it will help you not to wasting money on the belt. one of my friends after build it and play it rough only for 2 hours, the front belt and center belt skipped.
christanto_deng is offline   Reply With Quote
Old 07-07-2014, 07:04 AM   #11
Eeesh, well did you just order the same 519 that comes with the kit? Ive been taking it easy because im still learning cs. It isnt showing any wear at all, i loosened up the rear and front belt and it quit skipping. Then after about 2 hours of driving it started skipping again.
Old 07-07-2014, 11:54 AM   #12
ThePanda's Avatar
You want belts to be pretty tight, not super tight, but you should make sure they don't skip. If you drop your finger onto the center of one there should be a nice little bounce in the belt.
Old 07-07-2014, 12:44 PM   #13
Well on my main drive belt its loose abd floppy, top part reached abd almost hit the chassis support frame.
Old 07-08-2014, 03:45 PM   #14
ThePanda's Avatar
It should be a lot tighter than that. You want it as tight as possible without adding much drag to the system
Old 07-09-2014, 03:41 PM   #15
So you think if i ordered another 519 it would work or order a smaller belt?
