Is there a touring car ESC w/ hv bec? for HV servo?
#16
Find that very hard to believe. (does that make your arguement invalid as well?)
I do thing that HV in a TC is overkill but to each their own.
#17
I don't think its the ESC determines the voltage, more on the RX that distributes the voltage. And don't think its the voltage, 6v/7.4 are onlt the min/max voltage servo can draw. Better to look at amperage the servo takes. RX is more of your voltage regulator. My opinion.
#18
#19
That is not correct unfortunately. The ESC is what determines the voltage that is passed on to the rest of the systems (when running off the built in BEC). The RX just acts as a command and control module to pass along the input and voltage but doesn't hamper it in any way.
#20
The current modular design is actually pretty good. The esc doesn't care what voltage it's fed (up to a point, some are only good up to a certain voltage and some will brown out below a certain point) or really where it's coming from.
#21
The RX controls the signal to the servo (white wire). I do not believe it limits or controls in any way the voltage (red wire) to the servo however. It is a constant, limited by the BEC. This is why when you add an aftermarket BEC they have you disconnect the red wire from esc to rx.
#22
Umm the ESC puts out the voltage the BEC is set to give the RX. It passes threw the reciever and goes to the Servos. The RX doesn't control the voltage to the servos it just passes on what it gets. My 1/12th scale only passes on 3.7v to the servo cause that is all the battery will deliver (SANWA Super Vortex Zero with 3.7v Sanwa Servo) . My older 1/12th scale the ESC bumped up the voltage to 5.5 volts and that is what went the servo. There is no regulator in the RX.
#23
Some servos can't handle more than 7.4V but those than can will perform better at higher voltages. Its a relatively simple relationship.
Feed a motor higher voltage it will either go faster or die. Simple as that. You can approximate it for the same motor (ideally) as apply double the voltage you'll double the no-load speed, double the torque, and quadruple the power.
Go do some testing of your own with a stop watch and a battery if you don't believe me. Report back the findings.
On my 1/5th scale set up, I feed the receiver off the battery pack (to power it up) but pass out signal only. My servos are fed direct from the battery receiving the full 8.4V.
Not all receivers can handle the higher voltage though.
#24
SkyRc/Toro/Gforce TS120 is able to provide a 7.4V BEC... You also need the connection to a computer to activate it...
Check your RX before doing that...
