Old 08-25-2005, 11:31 AM   #1
Send a message via AIM to adr3naline fix
Default Is the Reedy Qusar good for charging my GP3300's?
I want a charger that is AC. (Plugs into the wall) The only decent one Im finding for under 150 bucks is the Reedy Quasar Pro.
Is this a good choice or should I be looking for a different AC charger?
adr3naline fix is offline   Reply With Quote
Old 08-25-2005, 12:53 PM   #2
I have it. I like it. It's pretty adjustable, so if you switch over to 3700s it won't be a problem. You can adjust the charge rate to at least 6 amps (that's the most I use) and it has a 20 amp discharger.
Make sure it has version 2.0 or later software if you buy it used. There was a software issue early on.
I think it gives you the best bang for the buck.
grazianos is offline   Reply With Quote
Old 08-25-2005, 01:03 PM   #3
yeah it is pretty cheap for what it does. Just wondering if It can compared to the more expensive chargers. Like the ones that use power supplies.
Anyone else have some input?
Bad for your 3300's in any way?
Old 08-25-2005, 01:04 PM   #4
It isn't a bad charger, I USED to have 2, then the recall came out and I had trouble with them, so then I sold them off and bot a LRP2 and I also have a duratrax ICE. The power supply is a bit of a pain but I've had no trouble with either charger and am happier with these then I ever was with the Associated.
Just my .02.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 08-25-2005, 01:38 PM   #5
i just want somthing that doesnt require a power supply.....
It doesnt need to have all the bells and whistles. Just so that I can change the amperage and can handle the 3300 batteries without problems.
So does the Quasar fit my description?
Old 08-25-2005, 02:05 PM   #6
Just set your delta peak at about 30mv and your charge setting at 6 amps if running stock, when you discharge at 20 amps for 0.9 cutoff 5.4 total for a 6 cell and you should be fine.
Old 08-25-2005, 02:10 PM   #7
I agree. You'll be fine with it. There's nothing to worry about.
Old 08-25-2005, 02:37 PM   #8
Yeti35's Avatar
Question is how many more threads is this guy gonna start on chargers before he decides to even listen to what anyone has to say?
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-25-2005, 02:40 PM   #9
josh69162's Avatar
Send a message via AIM to josh69162
I think he isn't getting the answers he wants to hear... Or he doesn't want to hear the answers he's getting...
-Josh
josh69162 is offline   Reply With Quote
Old 08-25-2005, 05:45 PM   #10
I get horrible response times in this threads for new questions.
ok. ill do it
Old 08-25-2005, 09:06 PM   #11
Yeti35's Avatar
ok. ill do it
It appears to me you are looking for responses to stuff you are trying to buy off Ebay at the last possible minute. Why don't you try to research before you bid, or better yet support you LHS!! So far you have not really listened to any advice people have given you thus far anyhow. People don't mind helping but if you try to contradict what they have to tell you then it makes it hard for them to want to help you at all.
22 3.0SR
Old 08-25-2005, 09:52 PM   #12
Ike
Ike's Avatar
If you're going to get the quasar you might as well just get the integy 16x7. It's the same charger but has a 30 amp discharge rate and never had the recall issues.
Ike is offline   Reply With Quote
Old 08-26-2005, 10:16 AM   #13
People kept suggesting the chargers with the power supply's. I dont want one with a power supply unless its cheap as all h3ll!
Im 16 years old. Do you really think I can easily spend 100 on a charger and anohter 100 on the power supply. Gas is like 3 bucks a gallon around here!
THe quasar #611B (the one Im looking at) is the after recall replaced version. But ok, Ill look into the 16x7. I acually have a zero equlizer discharger on the way so discharging really isnt that much of an issue. Thanks for the recommendations.
Old 08-26-2005, 07:38 PM   #14
ok I bought a quasar. Sorry for troubling everyone with questions. Ill soon be starting to race and I hope to give back to this RCTech forum community.
Old 12-07-2005, 03:53 PM   #15
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default help me please..
guys i have a 3600,3700,3800mah batts.. and i own quasar pro..
can u tell me what is the delta peak settings for that mah.... tnx guys..
nid reply soon..
and i heard that LRP releases it 4200mah.. what do u think will be the settings????
nikkiesteban is offline   Reply With Quote
Good Job @ Reedy Race Lil B!!! Tim Kowal Florida Racing 21 06-19-2008 11:43 AM
Novak XRS ESC, XXtra Receiver & Reedy GP3300's SA22C'ya R/C Items: For Sale/Trade 8 08-31-2007 08:30 AM
Tamiya TB-02R roller w/ Reedy GP3300's & RP30's SA22C'ya R/C Items: For Sale/Trade 14 08-04-2006 12:42 AM
any good web sites on battery charging? IBRCing Electric On-Road 4 06-29-2005 12:13 PM
GP3300's...are they good? lee82gx Electric On-Road 1 02-02-2003 10:19 PM
