Old 06-17-2014, 04:43 PM   #1
bornox's Avatar
Trader Rating: 26 (100%+)
Default yokomo r12w help
hey guys! i need some opinion about yokomo r12w would it be possible if i can use the yokomo r12c or r12c3 conversion? thanks!
bornox is offline   Reply With Quote
Old 06-18-2014, 03:38 AM   #2
IgorR's Avatar
A first conversion kit exist to convert from R12W to R12C a second one to convert from R12C to R12C3.
In the end it can be as expensive as a R12C3.
It's been a while since the R12W to R12C conversion kit has been released. It can be difficult to find it now.
My opinion go for a C3.
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 06-18-2014, 08:05 AM   #3
bornox's Avatar
amain has the conversions. so ur saying that i can convert my r12w to r12c or r12c3? thanks!
Old 06-18-2014, 12:05 PM   #4
IgorR's Avatar
First you need to convert a R12W to a R12C you need the kit: YOKR12-WCOV $135
http://www.amain.com/product_info.ph...Conversion-Kit
then convert your newly upgraded R12C to a wonderful R12C3 to do it you need the kit: YOKR12-C3COV $80
http://www.amain.com/product_info.ph...rsion-Kit-R12C
conversion cost is $ 215 + your R12W
To maybe save some money you can try to skip the first kit and buy the common parts between the R12C and the R12 C3. The list is long so in the end it can be $$$$.
Yokomo YR-X12
Shepherd Velox EC
Old 06-18-2014, 01:38 PM   #5
bornox's Avatar
thanks! i guess i'll just buy the c3 kit. its cheaper. thanks again for the help.
Old 06-20-2014, 05:20 AM   #6
IgorR's Avatar
About to be released the third conversion kit
http://www.teamyokomo.com/news/order...20_r12_rfc.pdf
Yokomo YR-X12
Shepherd Velox EC
