Old 06-15-2014, 12:59 AM   #1
Default universal shaft cushions
I finally built my m05 today with all my hop up goodies
unfortunately however, during assembly, I managed to snap one of these little cushions in half while slipping it over my dog bone
they came with my 3 racing gear diff.
1. Should I run these things/ do I need them?
2. do hobby shops generally stock these?
Dynikus is offline   Reply With Quote
Old 06-15-2014, 09:22 AM   #2
erchn's Avatar
Yes, you need them, otherwise you can ruin the universal or diff/spool.
Most shops carry them, but there are different sizes.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 06-15-2014, 10:45 AM   #3
the thicker your oil, the more frequent you need to change them. Or you could go for steel outdrives which you run without the c-blades/cushions
cheapskate.brok is offline   Reply With Quote
Old 06-15-2014, 02:25 PM   #4
whelp, none of the hobby shops I went to had them :/
I'm using some pretty thick oil, 300k
The 3 racing gear diff has steel outdrives though
Old 06-15-2014, 02:57 PM   #5
CraigMBA's Avatar
Trader Rating: 22 (100%+)
You need to get some. Missing that part will destroy the outdrive in a couple of laps.
Ask the hobby shop if they have some for another sedan. Tamiya uses two sizes, Associated uses them too.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 06-15-2014, 03:17 PM   #6
well I went to 2 shops, and neither shop knew what I was talking about. I'll just order some online
What the hell else are they called? the 3 racing ones are the only ones I can find.
Old 06-15-2014, 04:02 PM   #7
CraigMBA's Avatar
http://www.tamiyausa.com/product/ite...oduct-id=53890
Tamiya calls them a "swing shaft protector".
Old 06-15-2014, 07:05 PM   #8
mikel33's Avatar
Trader Rating: 2 (75%+)
tell them you are looking for the plastic caps a dogbone/driveshaft. Take one of the shafts and one of the cushions with you. If they sell r/c stuff, they'll know what it is.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 06-15-2014, 07:24 PM   #9
Another common name is "C Blade"
Normally either 3, 3.5 or 4mm width.
Here is a link to the 3.5mm 3racing ones;
http://www.rcmart.com/3racing-saku12...a-p-38680.html
When putting them on, use a little shaft grease - less chance of breaking when putting them on (they will still brake when driving though!)
cplus is offline   Reply With Quote
