Old 09-23-2002, 04:41 AM   #1
Wolf's Avatar
Send a message via ICQ to Wolf
Default Grease, which is which ??
Hi,
There are many grease out there for our RC cars, and I'm not sure which is which and where should it be used. I've search several forum for the info but there is not much info. Are you kind enough to tell me about it? I'm sure new commer are also interested to know their usage.
Which grease sould be use for:
1. differential ball
2. thrust ball in the differential
3. thrust ball in centax clutch
4. one way pully
5. bearing
6. servo gear
7. between outdrive and CVD
and there are some other grease that I'm not sure for their usage:
a. Tamiya Ceramic grease
b. Tamiya Molybdenum grease
(since they got names, I think they have some specific usage)
as well as
c. Associated clear grease
d. Associated black grease
(do you know actually which grease is inside?)
Thanks for your attention.
Wolf is offline   Reply With Quote
Old 09-23-2002, 06:57 AM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
1. AE White
2. AE Black
3. AE Black
4. Serpent one way
5. Trinity Royal Oil
6. Tamiya Ceramic
7. MIP red, or AE black............
dtm is offline   Reply With Quote
Old 09-23-2002, 10:18 AM   #3
Manticore's Avatar
R/C Tech Charter Subscriber
I would rather do this but mostly same.
1/. AE gold label clear gease
2/. AE black gease
3/. Parisracing gease
4/. Serpent oneway lube
5/. Serpent oneway lube
6/. Racer's choice Hyspin+
7/. Parisracing gease
Manticore is offline   Reply With Quote
Old 09-23-2002, 10:33 AM   #4
Wolf's Avatar
Thanks.
Oh. I've used the Tamiya Ceramic in one way bearings!
Then I'll get some Serpent one-way next time I visit LHS.
Old 09-24-2002, 07:49 PM   #5
TeamGoodwrench's Avatar
Along these same lines...
I've seen articles about cleaning and re-lubing bearings.
Many of them say to use a white lithium grease to re-lubricate the bearing before putting the shield back in place.
Who makes this stuff or where do u get it ? Anybody done this ?
Thanks.
TeamGoodwrench is offline   Reply With Quote
Old 09-24-2002, 09:14 PM   #6
Wolf's Avatar
I've also heard the use of telfon lube. Anyone know what is it?
Old 09-24-2002, 09:32 PM   #7
Manticore's Avatar
Thanks.
very depending on the result you want to achieve. if you want speed, you need to only use very thin layer of lubricant oil such as serpent oneway oil.
If you want to protect the internal of the bearing for longer life. you need a thicker grease.
it is just a give and take choice.
Old 09-24-2002, 09:43 PM   #8
Manticore's Avatar
HPI has kind of those telfon lube and they are for belt/pulley, ball ends and gears.
Old 09-25-2002, 04:53 AM   #9
dtm
dtm's Avatar
Yes...it kinda works on the belts....for about 5 packs!!
I also built my 2nd Xray with the stuff on the ball ends......can't say I noticed much difference though??
Old 09-25-2002, 04:56 AM   #10
Manticore's Avatar
at least it works !
Grease nsgland Nitro Off-Road 12 08-18-2008 12:30 PM
Do you grease your gears? chin Singapore R/C Racers 8 02-18-2008 06:46 AM
grease... n3rd420 Rookie Zone 7 05-29-2006 06:10 PM
Tamiya Anti wear Grease or Ceramic Grease..?? TRFTIM Nitro On-Road 6 04-24-2006 11:52 AM
Silicone Diff grease, Axle thrust grease holycow Electric On-Road 3 10-25-2003 11:33 AM
