Old 06-08-2014, 12:32 AM   #1
Default TRG 114
Hello
Who has some setup tips for a TRG114 with Foam Tyres on a Asphalt Track.
The Car oversteers at the end of the straight.
Regards
olli68 is offline   Reply With Quote
Old 06-08-2014, 07:33 AM   #2
EDWARD2003's Avatar
I would suggest posting your setup.
Post everything!
EDWARD2003 is offline   Reply With Quote
Old 06-08-2014, 09:00 AM   #3
Hello
Here my Setup
Regards
Old 06-08-2014, 11:43 AM   #4
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
The first couple of things I would start with are tightening up the rear diff (I ran a TRF101 but always ran my rear diff tight being careful to slightly tightening the diff until there was no slipping) along with reducing the amount of treated area on the front tires (start by treating on 1/2 of the tire then increase if you are needing more steering)
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 06-08-2014, 05:41 PM   #5
EDWARD2003's Avatar
You're running 62 and 63 mm tires! Wow! Those tire diameters are huge! I would suggest truing them down to at least 55 front and 57 rear.
Your saucing techniques could be your main culprit.
For the rear I sauce full 40 mins
For front I would sauce 1/4 first or try OnRDPassion suggestion of 1/2. 10 to 15 mins.
Shock oil, I would go up to 50 or 70 wt.
