Old 09-25-2002, 02:16 PM   #16
TeamGoodwrench's Avatar
Why mess around with that ? Just get a Millenium Pro and select the NIMH-2 charge mode and press the button !
I do have 2 T-30's that I also use for my 2400's and for discharging and motor run-in, but my NIMH packs only get charged on my Millenium Pro.
TeamGoodwrench is offline   Reply With Quote
Old 09-25-2002, 04:11 PM   #17
Impreza's Avatar
Send a message via ICQ to Impreza
Can an older T30 safely charge ni-mh packs? I have heard from some people that even with the voltage threshold T30's shouldn't be used on ni-mh as they don't have "ni-mh software"? Is this true?
Impreza is offline   Reply With Quote
Old 09-25-2002, 04:13 PM   #18
I don't think any of the T-30/35's have special "NIMH software".
They just have settable voltage threshold and plain old linear charge mode.
Old 09-25-2002, 05:15 PM   #19
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
you can definatly cage nimh packs on a t- or t-35....i do it week in and week out.....set your peak, and set your peak threashold, and charge....i do not use the flex mode, just the regular charge....i have had no problems.....
Matt M. is offline   Reply With Quote
Old 09-25-2002, 08:00 PM   #20
Impreza's Avatar
Allright, just wanted to make sure.
Thanks!!
Old 09-25-2002, 08:54 PM   #21
Big Al & mr Losi,
Thanks for info.
I will have a try with a 2 peak setting.
Awesome is offline   Reply With Quote
Old 09-26-2002, 04:28 AM   #22
RC Nitro's Avatar
Guys: Give Jim at CE a call. They have been great in answering my questions on the T35 and TD45. They upgrade and costs were reasonable. Ex upgrade TD30 to TD45 with new prom was $100, B/L upgrade is $50, and black case is $20.
RC Nitro is offline   Reply With Quote
Old 09-26-2002, 07:55 AM   #23
What's his phone number ?
Thanks.
Old 09-26-2002, 07:58 AM   #24
RC Nitro's Avatar
fax:815 874-8181
ask for tech support
8-4pm central time
Old 09-26-2002, 08:04 AM   #25
Cool thanks.
I've got 2 T-30's that I'd like to get re-calibrated, updated ROM, and a backlight put in.
Old 09-26-2002, 09:19 AM   #26
newracer's Avatar
R/C Tech Charter Subscriber
anybody ever have problems discharging/cycling nimh cells on a T-30? A friend of mine has one and says that when trying to cycle his nimh cells he gets a voltage too high error. If he lets the pack sit for a while after charging then it will discharge.
newracer is offline   Reply With Quote
Old 09-26-2002, 09:26 AM   #27
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
Goodwrench....i talked to Comp. electronics a while back and they didn't recommend the backlight upgrade for the T-30 they had at that point been having a few problems with the ones they had upgraded
myclod is offline   Reply With Quote
Old 09-26-2002, 01:42 PM   #28
Hi Newracer,
Yes, it happend to me also.
I tried to cycle my old Sanyo 3000 (not HV).
And got also the same error message.
However I didn't try to lower the discharge Amps to 25 or 20.
I think the T30 can't handle the high voltage when a pack of batteries has just peaked. The voltage would drop after a few more seconds and the T30 would discharge them.
I will confirm this when I tried it out.
But have to wait, I lend out my T-30 for a few days.
Old 09-26-2002, 09:04 PM   #29
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
I think the older version software is set to a certain peak voltage and the newer version will accept the higher output voltage fot he newer cells......If i'm wrong let me know but I think that's what Jim from CE told me. I hope this helps.
picco007 is offline   Reply With Quote
Differences between M03 & M04? big al Electric On-Road 15 10-05-2015 10:02 AM
turbo 35 and turbo 35 gfx differences xrayflorida Radio and Electronics 1 06-04-2008 02:54 PM
Differences between 3port vs 5 port, Turbo vs Non turbo nikkor Onroad Nitro Engine Zone 2 09-28-2005 06:24 PM
Turbo 35gfx versus BL Stealth...any differences? jlou671 Electric On-Road 9 09-30-2004 11:52 PM
Turbo 35 charger differences? rcpilot Electric On-Road 67 02-11-2003 09:43 AM
