Old 06-03-2014, 02:32 PM   #1
Location: Beneath a rock down by the river. Don't have money for van
Default Hong Nor OB4 electric revisited.
A long time ago I had a nitro TC, electrics were available but 5 minutes runtime were not inviting, we're talking 2400Nicads here
So a couple months ago I saw a cool TC, saddle pack, centered motor, PBS suspension...Absolutely different from the Tamiya 415 and sequent cars(except the Xray T1 for obvious reasons). Well, it came with brushed electronics and I really liked it because it's so different and I think I can do something very special using a shorty battery. I'm going to add a couple pics and show my progress here.
The plan is to use a BL system with a shorty, make a new chassis and maybe enter some competition with it. If anyone has tips and tricks, chassis ideas, etc..just say.
Stay tuned
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 06-05-2014, 01:17 PM   #2
eR1c's Avatar
sorry, maybe I missed something,
Why is this thread called "Hobao OB4 electric revisited."???
eR1c is offline   Reply With Quote
Old 06-06-2014, 04:11 AM   #3
No need to be sorry. Being a non-native English speaker I thought it was kind of fitting, because the OB4 is old and forgotten and now there is interest in out of ordinary looking TC's. So I'm converting the old girl to BL and LiPo saddle pack, new technology with the concept of PBS suspension and saddle packs on a electric TC. Maybe I should of waited a bit more to gather more pics and progress?
Bonus info, I've found that Kyosho ZX5 bladders work on OB4 shocks, you can use the ZX5 top shock mounts which are 1mm shorter but way stronger and are drop in replacement.
Old 06-06-2014, 05:48 AM   #4
howardcano's Avatar
Trader Rating: 35 (100%+)
If I recall correctly, the OB4 has an issue with the design of the front uprights: There is no inner "lip" to prevent the (unflanged) bearings from moving sideways. It might be possible to use flanged bearings, or modify the upright.
This was one of several issues with the car that made me finally give up on it. The concept was neat, but the execution... not so much.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 06-06-2014, 07:08 AM   #5
I've just took apart the front upright. Good news, there's a inner lip between the bearings. Apart from design flaws that affect working on the car I haven't experienced any shortcomings
BTW, sir you have a PM.
Old 06-06-2014, 07:53 AM   #6
howardcano's Avatar
Okay, I plead old age for bad memory! Maybe I broke through the lip with my many encounters with the boards. Or maybe the uprights were updated to fix the problem.
I ran the OB4 as a "poor man's XRay" until I bought my first T1.
On of the biggest improvements on the OB4 would be updating the front to a gear diff. I don't know of any that fit, but it wouldn't surprise me if there are diffs from other cars that could be kluged in.
Howard Cano
Old 06-06-2014, 08:06 AM   #7
I would not be surprised if it broke, it's minimalistic.
If all else fails there's the nitro OB4 gear diffs. Diff is approximately 17.7mm bearing to bearing (inner bulkhead measure)and has a 35 tooth count if not mistaken, too narrow for today's standards afaik.
Old 06-06-2014, 08:19 AM   #8
howardcano's Avatar
It's probably the same diff as used in the JL10e Drift (which is just the OB4 Mid with a new name). It might be a little heavy, but strong!
Howard Cano
Old 06-06-2014, 03:50 PM   #9
And so the hunt begins, JL10e gear diffs will be. Not that I have any sort of problems with the stock ball diffs but plastic outdrives, it's just living dangerously. Oh and JL10e drift front uprights were updated, now have 3 ackerman positions. The complete JL10e steering setup should reduce bump steer, I had to shim the rack up 3mm and mount the balls beneath the upright.
Old 06-06-2014, 05:52 PM   #10
howardcano's Avatar
Correction to my previous post: The OB4 Mid/JL10 Drift gear diff uses the same gears as the Nitro OB4, but the housing, pulley, and outdrives have different part numbers. I think the Mid/Drift diff might have the best chance to fit properly.
I agree about plastic outdrives. The first TC I bought was a TC3, and when I saw that the outdrives were plastic, I vowed to never buy another Associated car. Fortunately there were steel upgrades available for it.
Howard Cano
Old 06-07-2014, 07:17 AM   #11
Being the JL10 is "newer" I might have more luck finding parts here. I'm thinking about adding the rear gear diff too.
Old 06-07-2014, 11:54 PM   #12
alcyon's Avatar
URL=http://s185.photobucket.com/user/alcyon2sp/media/Mobile%20Uploads/20140513_162044_zpsrm45hav0.jpg.html][/URL]
The ob4 is a lot like the rclab 77 . I have done an experiment similar to what you plan to do..on my same era kawada sv10 II. I used the original suspension, bulkheads top decks motor mount...i designed a new super narrow lipo chassis, mounting for vbc floating servo mount to make the flex equal on both sides.i also was able to fit trf417 gear diffs which changed the ratio. Because of that i used 3racing 17t top pulleys compared to the originals 16t. The ratio was 2.25. Now its 2.1764.
Before this there was a guy with a bd7 who used 7200mah batteries who kept beating the crap out of my kawada . Just 2 nights ago i went up against his bd7..still i was using 4200mah shorty pack and guess what..he ate my dust hig time ! The centered mass design coupled with equal flex left and right transformed my kawada into a nuetral handling tc with a lot of steering without rear end washing out.
the funny thing was every week he would keep telling me not to suffer and just buy a modern car. Well after i beat him he just kept quiet and kept trying to fix his car..when there was nothing wrong with it actually .
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 06-08-2014, 03:39 AM   #13
howardcano's Avatar
Originally Posted by alcyon View Post
[/URL]
That is one beautiful chassis! What tools did you use to cut the carbon fiber?
Howard Cano
Old 06-08-2014, 04:23 AM   #14
alcyon's Avatar
Hi there thanks for the compliments. I only designed the chassis on solidworks and convetted the drawing to autocad. All materials cutting and drilling were done by fibrelyte in the uk.
Old 06-08-2014, 04:17 PM   #15
*snip*
Great work and congratulations on your achievement.
I see you can mount the battery way in a place I can't, the belt gets in the way. I'm thinking of making two chassis, one for saddle pack and another for a shorty. The saddle one will be similar to stock but without the cut outs for Sub C cells, I just have to make 2 cradles and a new top deck because the battery plugs don't clear the top deck. The shorty one will have the battery mounted lengthwise and thanks to your idea will use a floating servo mount to flip the servo to the left side, so I can mount the battery more inward. I'm just waiting for the completion of the pin router and G10 sheets.
