Old 08-22-2005, 04:38 PM   #1
Default Question about "Punch"
Okay, hopefully I can explain what I mean without sounding like a complete fool . Let's say a motor draws 10 amps (round numbers)...Battery A can pump out 30 amps....Battery B can put out 15 amps. Will Battery B be less "punchy" than battery A? Does this make sense to anyone? I hope you understand what I am getting at
Thanks!
RCevolution is offline   Reply With Quote
Old 08-22-2005, 09:41 PM   #2
schmelme's Avatar
Punch comes from volts available to the motor not the amps. I dont think todays packs are lacking available amperage even for hot mod motors. More volts=more rip.
schmelme is offline   Reply With Quote
Old 08-22-2005, 09:49 PM   #3
Joel Lagace's Avatar
In order to sort your battereis you need to know what there average dischage voltage is and how long there run time is.
ITs all about high average discharge voltage. You will get more punch with higher voltage batteries. The amp draw will come from the motor,gearing,traction and voltage output of a battery.
If you do not have a charger that can cycle your batteries you can normally find a guy at your local track or shop that can cycle your packs for you. You will get the average volts and run times as well as internal resistance ect ect..
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-22-2005, 09:51 PM   #4
Don't forget about low internal resistance...The lower,the more punch also!As the amps can flow to the motor faster!!
Ben.C is offline   Reply With Quote
Old 08-22-2005, 10:44 PM   #5
Thats right, you need equally as low IR's to let the voltage flow to the motor. Its kind of like water flow, if you have the same pressure but two different openings, the larger opening will let the water flow faster...but in this case the lower IR will let the voltage of the battery flow to the motor
Dhartman03 is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
"Asleep" Ni-Mh cells: they've lost their punch cRIMSON_dAWN Rookie Zone 5 11-01-2006 04:37 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Improve battery "Punch" discus18 Electric On-Road 37 01-19-2004 07:09 AM
