48p spurs for 1/12th scale? >
Old 05-31-2014, 08:00 PM
WheelNut's Avatar
Default 48p spurs for 1/12th scale?
I'm running my Xray X12 on not so perfect asphalt so I need to run a 48p spur. I've got an HPI 67 tooth installed now, but it would be nice to have a 60t. I can't run the small diff ball pattern with the Xray diff rings though, so I can't use the small robinson gears. Any ideas?
WheelNut is offline
Old 05-31-2014, 09:15 PM
xrayracer1's Avatar
I'm using a Kimbrough 72t spur and 30t pinion on my Associated 12R 5.2, but im running euro stock with a 10.5t motor. Kimbrough I think goes down to a 65t spur.
xrayracer1 is offline
Old 06-01-2014, 03:10 AM
howardcano's Avatar
Trader Rating: 37 (100%+)
I'm running this Traxxas 60T, #2519, on one of my cars:
http://www3.towerhobbies.com/cgi-bin...?&I=LXJE77&P=7
It needs 3/32" diff balls. You may need to open up the center hole a little with a reamer, and/or add a 1/32" shim to compensate for the smaller balls.
I have also run the small Robinson machined spurs by chucking up the diff rings in a drill press and grinding down the OD on the diff rings. But of course that won't change the diff ball pattern.
None of these things were on an XRay, but I'll bet you can kluge something together similar to the above.
howardcano is offline
