Sakura D3 problems
Sakura D3 problems
I have had a sprint 2 drift for about a year now and decided to upgrade. I was always fond of the Sakura kit and finally got to order it and it was fun to build and seems awesome. I am new to the CS world so bare with me, but im having some issues. I am running a speed passion combo 3.0 10.5T system. I ran the car for the first time today and slow it works fine but when i get close to full throttle the front wheels shake realllll bad. The main drive belt flapps real bad and wheels bounce up and down, anyone else had these problems?
Also the motor and esc combo do i need to hook up the sensor wire or run sensorless?
For drifting it's all about control, so yes you want to run the sensor wire. As for the wheels shaking, have you checked the diff and axles? It sounds like something wasn't put together quite right and is binding at certain points in the rotation, or something along those lines..
Also 'alot' isn't a work in the context you're using it in, it should be 'a lot'.
Thanks for correcting the name, i do know that, but i had reached the limit of characters, and i didnt care its just a name so dont be a jerk.
I have checked everything and its all tight, i wondered if i got to big of a belt because i have read they mess up on the belts for the kit often.
Figured it out, the main belt is skipping teeth on the rear pulley and making it twitch, it is the 519 should i get a 517? Also the front wheel chatter is becasue the stock cvd's cant handle that much of a angle, is that correct as well?
Well i just went from the sprint 2 and have wanted this chassis for a while. Ive already got alot into it to get it goin so another 40 bucks for shafts and another belt wont be to bad really.
Thanks man, im gonna order some!
for the skipped belt, i did have the same problems and i changed to the new one. and IMHO don't push the throttle suddenly just keep it smooth and it will help you not to wasting money on the belt. one of my friends after build it and play it rough only for 2 hours, the front belt and center belt skipped.
Eeesh, well did you just order the same 519 that comes with the kit? Ive been taking it easy because im still learning cs. It isnt showing any wear at all, i loosened up the rear and front belt and it quit skipping. Then after about 2 hours of driving it started skipping again.
Well on my main drive belt its loose abd floppy, top part reached abd almost hit the chassis support frame.
So you think if i ordered another 519 it would work or order a smaller belt?
