ORCA brushless motors and LRP Flow WT ESC compatibility
Hi guys,
someone is aware of problems of incompatibility between ORCA TX motors and LRP flow wt ESC ? Last time on track happens that after 4 min the motor performance drop significantly. I use LRP flow with new firmware 4.7 and ORCA 6.5T brushless motor. Thanks in advance cheers Carlo |
Originally Posted by charlie63
(Post 13273382)
Hi guys,
someone is aware of problems of incompatibility between ORCA TX motors and LRP flow wt ESC ? Last time on track happens that after 4 min the motor performance drop significantly. I use LRP flow with new firmware 4.7 and ORCA 6.5T brushless motor. Thanks in advance cheers Carlo Did you changed the timing from the motor and the esc? |
Originally Posted by nikoskar
(Post 13275649)
anyway at the end of the run (6/7 min) the motor temperature was not greater than 65°C and ESC 55°C. |
Have you checked your batteries?
Originally Posted by Odin544
(Post 13275732)
(Post 13275722)
yes I've setted Mode 6, 7 and 8 to value 6 (others remain standard) and also modified timing on the motor, I think that was setted to 20°.
