Old 05-17-2014, 08:10 PM   #1
Suspended
Default touring bodies
im not a just b/c it looks better body person...
what are some good durable bodies
ones better than hpi
190mm or 200mm
kongluc is offline   Reply With Quote
Old 05-17-2014, 11:00 PM   #2
Suspended
90 views and no comment? really?
Old 05-18-2014, 01:48 AM   #3
Geberit's Avatar
PF MazdaSpeed6 LW #1487-11 for Carpet
PF LTC-R LW #1505-25 for Asphalt
That's what 99% of pros at the ETS are using and also the regular drivers.
Geberit is offline   Reply With Quote
Old 05-18-2014, 08:39 AM   #4
dan_vector's Avatar
Trader Rating: 27 (100%+)
If you looking for durability over weight then go for the Normal weight bodies not the light or pro-light versions. Also make sure your edges are smooth to prevent cracking. I've always used protoform bodies as I've found them to have the highest quality lexan IMHO.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 05-18-2014, 09:28 AM   #5
locked's Avatar
There are things you can do to strengthen any shell, like applying a generous layer of shoe goo all in the nose, around the splitter, front wheel wells and back corners. Some people embed drywall tape or even fibreglass cloth in the shoe goo for extra strength. Even just using a little shoe goo in key spots will help extend the life of a shell without affecting the handling too much. If you get too carried away, it can affect performance by raising the COG and shifting weight forward.
Thicker lexan will tend to be a bit stronger, but will crack in a hard collision and raises the center of gravity, so the car will have more of a tendency to flip in high grip conditions. Thinner lightweight lexan will still crack and can even have sections tear right off, but for performance in high grip, it's what most racers use.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-18-2014, 10:51 AM   #6
chasingthepack's Avatar
well you didnt give much info,what car is the shell for? what do you want to do with it?
ie race/bash? what are you looking for in a shell? more downforce or less for more top speed? do you need a tougher/thicker lexan to make them last longer?all these things must be taken into account before anyone can recommend a shell for your requirements
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-18-2014, 02:10 PM   #7
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
Protoform LTCR LW
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 05-18-2014, 07:35 PM   #8
sashimi999's Avatar
As chasingthepack mention, depends on what purpose would you like to run for.
for formal racing, there are limited types of brand bodies you can choose from. i.e. Protoform, BittyDesign, Blitz, HotBody. etc. Just go to ROAR or EFRA official website to check out.
for bashing/casual racing, choose anything you like.
All body shells are made of Lexan and will eventually break. but you can re-inforce them by correct tapping and apply Anti-Tuck Body Stiffeners.
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
Old 05-18-2014, 07:57 PM   #9
mikel33's Avatar
Trader Rating: 2 (75%+)
As one of the previous posters said, what do you want to do? Race? what class? vta, usgt, touring car? More information from you would help get you an answer.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 05-19-2014, 05:54 AM   #10
Suspended
no racing just like some gymkana style stuff at the mostly on road and a mixture of off road. nothing like those videos you see on youtube where you do one frame at a time.
my car is an hpi sprint two
Old 05-19-2014, 07:44 AM   #11
mkiiina's Avatar
Trader Rating: 69 (100%+)
Then disregard pretty much everything above as you have wasted their time.
HPI bodies are pretty good and there really isnt a great body that will handle off-road. Bodies crack over time and crashing helps.
That said the shoe-goo and either fiberglass/drywall mesh does help alot. My vta bodies all get that treatment and it helps them last longer, they still crack.
Look at http://www.mcallisterracing.com/ for some options. Tamiya is another.
That said, the HPI bodies are probably your best bet.
mkiiina is offline   Reply With Quote
Old 05-19-2014, 08:12 AM   #12
Suspended
I once bought an hpi body...got it all painted up and when I pulled off the overspray film the body had a lot of places where the only thing holding it together was the overspray film...so im tryin to stay away from hpi
I don't see how I was waisting anyones time...this is an onroad forum
Old 05-19-2014, 08:50 AM   #13
oeoeo327's Avatar
Trader Rating: 74 (100%+)
HPI bodies occasionally run into the "thin spot" problem, but the occurrences are few and far between. For the most part, their bodies tend to offer good detail and durability. Before painting the body, check the body for obvious defects (like thin spots) and you could save yourself a lot of headaches.
It would have been a little easier if you stated the intended use of the body in your first post - many on-road racers (and off-road racers, for that matter) don't use any one vehicle on multiple surface types - since you posted in an on-road forum, it was assumed that you were using your car on a typical on-road surface, meaning asphalt or carpet. Therefore, most of the recommendations were geared towards that assumption.
While you weren't really intending to waste anyone's time, per se, a little more detail in the first post would have helped guide our suggestion process.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 05-19-2014, 08:54 AM   #14
MikeXray's Avatar
Trader Rating: 73 (100%+)
This make no sense.
I've had a few HPI bodies, the STI is very durable, the E30 M3 is not, the hard lines in the mold cause the bumpers to crack very easily. The e90 M3 bodies are durable as well. Tamiya are high in detail, and some are durable, and some are less, you can kinda see it by the molding.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-19-2014, 10:06 AM   #15
Suspended
Originally Posted by MikeXray View Post
This make no sense.
I was trying not to double post
