Old 05-16-2014, 06:22 PM   #31
Yep just tried it that was not the problem same thing just slides everywhere very consistent it just never has any grip when it gets out of shape it just never comes back like its on drift tiers
Larrysraceprep is offline   Reply With Quote
Old 05-17-2014, 12:39 AM   #32
Suspended
Smile
It seems like you've tried everything so far.... It might not be a setup issue, but rather a wheel bearing catching and messing everything up, or a binding CVD, body rubbing Tires, etc....
bertrandsv87 is offline   Reply With Quote
Old 05-17-2014, 05:24 AM   #33
poochy's Avatar
ur tires are all glued to the rims and not peeling off?
ur dual rate is not too excessive?
ur not saucing with something too greasy?
poochy is offline   Reply With Quote
Old 05-18-2014, 10:10 AM   #34
Nope I do my prep like everyone els I go throw more tiers than anyone out there I'm starting to think one of the problems might be my servo I'm a pan car drive so I use a slower servo what is a good 50-100$ servo to run?
Old 05-19-2014, 04:37 AM   #35
tc3team's Avatar
Futaba s9551.
Slim and good spec for the $
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 05-19-2014, 07:10 AM   #36
9551 or 9550 ?
Old 05-19-2014, 07:38 AM   #37
oeoeo327's Avatar
Trader Rating: 74 (100%+)
They are essentially the same servo (9551 vs 9550), and both are a solid choice. The 9551 is the newer model, so I'd lean towards choosing that one. What servo are you using now?
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 05-19-2014, 01:09 PM   #38
Hs-625mg
Old 05-19-2014, 01:16 PM   #39
oeoeo327's Avatar
The servos mentioned would be a huge improvement over what you're using now. The HS625 isn't even a digital servo, which I'd consider the first requirement in making a choice. Futaba's 9551 would be an excellent pick.
Old 05-19-2014, 08:04 PM   #40
Suspended
Smile
That servo is too slow(0.15sec @6v) , and too weak at 94oz...... You need at least 0.10sec and 110oz in tc....... Digital is preferred over analog for its centering superiority,etc..... Good luck....
Hs-625mg
Old 05-20-2014, 04:22 PM   #41
Looks like you can't get a 9550 anymore the 9551 is a little slower 0.11 is that ok I don't mind spending a few extra $ to get the next step up and what would that be there are lots of deferent servos with better rating is there a brand I need to avoid or are they all good?
Old 05-20-2014, 08:36 PM   #42
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Scan Ebay. I've had a 9550 for about 5 years and it has been great. A good use done should only run you about 30-40 shipped.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 05-20-2014, 11:18 PM   #43
Suspended
Smile
What about the BLS551 ??? I know it's expensive, but at least it's brushless: lots of torque with no fade.....
Old 05-21-2014, 07:14 PM   #44
oeoeo327's Avatar
BLS-551 - REALLY good servo. Worth the price tag, IMO... If money's no object, it's a really good choice.
Old 05-22-2014, 09:27 AM   #45
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Originally Posted by gdcopbdcop View Post
i can see here part of your problem lies...
#1: it looks like you have 1000 t gear diff oil. I never go belo 1500, I use mostly 2000 t.
#2: The first thing I would get is the 3 notch camber link plates. They are a different size than the 4 notch stock camber link plates, and really help the car.
#3: your rear camber link has 2 mm spacers under the ball. go to 2.5 mm spacers under the ball link. That alone will give you more rear traction.
#4: I would try using 400 wt oil in the rear.
#5: Try a blu 15lb spring in the rear.
#6: Probally your biggest problem is the droop. You have 4mm droop on the front and rear. Try 1 to 1.5 mm more droop under the front end then the rear end. You need the car to shift from front to back. The droop makes this happen.
Try those out, and get back to us.
Does anyone else have any other suggestions?
if I'm reading the setup sheet correct
you're running 50% rebound.
that is way too much...let the spring do the work.
I never run more than 10%, most of the time as close to zero as possible.
try the softest shocks first then work up.
also, as someone mentioned make sure the arms are falling under it's own weight...can easily bind if not placed on correctly.
Lot's of people trying to help ya...very nice to see....
My Mi5 has been very good since day one...run stock and mod...always had too much traction.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
