Old 05-13-2014, 03:26 PM   #16
Ok thanks ill try more camber gain and diff oil I did try softer spring it might of been a little better I was thinking of softer sock oil Just doing a side by side test next to my friends Xray my car felt twice as stiff all the way around I tried 1b springs in the rear and 14lb in the front what is so strange is I have made major changes to this car and nothing has made a much of a change I know people are making this car work very well at other tracks and it just suck being the only one at the track with this car and doing all the R&D by my self
Larrysraceprep is offline   Reply With Quote
Old 05-13-2014, 03:37 PM   #17
Reese Bobby's Avatar
Hi. It might also be worth looking at your tyre prep. Also some chassis have a narrow setup window, I am not sure about the Mi5 but I know that others like the D06 and T4 setups can be generally carried between tracks. Like one of the others said, have one of the top guys take it for a few laps.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 05-13-2014, 03:49 PM   #18
TryHard's Avatar
Looking at that setup, what I feel you've done is make the front too stiff so as too take away grip, then changed the rear of te car to get steering back... Which has only ended up to compound the problems. My advice is;
  • 450 in all shocks, and drill a hole in the top cap whilst your at it to vent them. I also prefer to build my shock with zero rebound, always.
  • Set droop to 3.5 in the rear, and 4.5 at the front. Never run more droop on the front than rear, car is going to do some very strange things that way.
  • 1500 - 2000 in rear diff - thicker oil will help to take away initial steering whilst give back some on power.
  • Move rear shock out one hole on the rear tower
  • 0.5mm under all lower suspension balls
  • go to 1mm shim under rear inner upper camber link ball, and nothing under the front
  • put 1mm shim on rear axle - more stable, end of.
  • put on a new set of tyres
That should get you much closer to the ball park, with a car that will probably push a little, but is consistent to drive with decent grip. Once that's settled, then look at things like the 3dink plates, springs, rear hub plates etc for extra tuning options.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-13-2014, 04:05 PM   #19
Yes that was the first thing I did was have everyone els drive it to make shire it wasn't just me and that's y I'm here many people have tried there setups on it and I have tried all the setups on line I could find with no luck if it was just a toning thing I could work it out or get it almost there but it's so fare out idk what to do it just feels like they do on the first lap that the tire sauce won't come off but it never gets any better
Old 05-13-2014, 04:16 PM   #20
Cool thanks that makes sense do you think I should go lighter on shock oil in the rear?
Old 05-13-2014, 05:28 PM   #21
TryHard's Avatar
Honestly, start out with equal front and rear. At the moment you want to make the car safe to drive. If it has a little push, that's fine, it'll be more consistent that way, and get your confidence back. Once you've done that, start hunting for more steering.
Something else I forgot to mention is also look to change the rear arms to the 2.5 ones. The 3deg actually give a little over 3deg of toe, whereas the 2.5's are much better suited to 13.5 blinky. I actually use the 2.5's all the time on my mod car anyway...
Also, what are you doing in terms of tyre prep? And what sort of ambient? I assume that you have asked around the pits on advice of how to get the Sweep40's working? As that will also have a big effect.
HiH
Ed
Old 05-13-2014, 05:50 PM   #22
I started with the 2.5 arms it was a horrible !!!!
Old 05-13-2014, 05:50 PM   #23
Old 05-13-2014, 06:16 PM   #24
One more thing I just put the car on the scales and this it what I got if it even matters rf 288.8 lf 282.8 rr 287.4 lr 309.2
Old 05-14-2014, 05:01 AM   #25
poochy's Avatar
chck u r using all 4 matching sweep 40s tire
or
check the arms are falling freely
if not...re-read the manual on how to tightn it without binding it.
poochy is offline   Reply With Quote
Old 05-14-2014, 01:00 PM   #26
ASM
ASM's Avatar
Trader Rating: 21 (100%+)
You could always try posting on Martin Crisp's thread for help and in addition, give learnsetup.com a try. It's well worth it and is a great trackside aid.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-15-2014, 05:45 AM   #27
Damon's Avatar
you have to control the front slider inserts (U3814)
specially in front with spool and ECS they wear quickly and block the slide of bones
it results in an undriveable model and any change of setup is useless, you have just to replace the inserts
I had the same problems
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 05-15-2014, 02:49 PM   #28
ASM
ASM's Avatar
Looks to me as though your car has been on ebay for 6+ days - up for sale.
Scott Meeks
USVTA Member #116
Old 05-15-2014, 05:40 PM   #29
Yes I found some bad inserts do you use the black or gray ones ? And yes out of anger I put it on ebay lol but I'm so deep in the thing idk if it will sell might be stuck making it work
Old 05-16-2014, 06:05 AM   #30
Damon's Avatar
have you tried the car with new inserts? I'm sure those are your problem!
however, I use both grey and black inserts, but every 2-3 days on the track I check them and if they are slightly worn I replace them immediately
Awesomatix A800
Awesomatix A800X
