Old 08-17-2005, 03:33 AM   #1
Mr-s413bt's Avatar
Default Blistering Tires
Heya Ppl.
Ok being new to onroad, i have one question for everyone.
I have been running my 415 on Carpet and Ashphalt and the car is quite good.
But i am finding my tires blister a bit after a few runs, is this normal? Is there anything i can do to stop it???
I am not running excessive camber (1 degree) and nothing else really seems wrong.
Any help would be great!
Glenn
Mr-s413bt is offline   Reply With Quote
Old 08-17-2005, 03:39 AM   #2
TryHard's Avatar
two questions, what tyres are you running, could be the compound is too soft. Also whats your driving style like, do you like the car to slide? or keep it smooth?
To be honest, tyres graining is quite hard to stop, I just grin and bear it. (Outdoor work tends to knacker them the easiest)
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-17-2005, 03:50 AM   #3
maybe the tires are too soft (low temp rating) or the inserts are too soft or thin. in other words, try harder tires/inserts
billtc3 is offline   Reply With Quote
Old 08-17-2005, 04:07 AM   #4
Mr-s413bt's Avatar
Heya Guys.
Yeah i am an offroad guy to start with, i am starting to think i may be a little aggressive with the car.
Currently i have been running Take Off CS27's with medium inserts in preperation for a major meeting in 8 weeks or so. Mind you the temps here have been around 17-20degrees air temp and track temps not much more!
I guess i better get used to it!
Glenn
Old 08-17-2005, 06:43 AM   #5
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Thats just how rubbers wear, asphalt especially, rolls and tears the rubber off the surface of the tyre, dont be allarmed.
dontfeelcold is offline   Reply With Quote
Old 08-17-2005, 07:03 AM   #6
Also try different traction compounds, some will cause the tire to cook faster than others on different surfaces, they need to rename rubber racing chemical racing, the fastest compound wins.
Try setting the car up to have more grip, if the car is loose the tires will also wear faster.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-17-2005, 03:59 PM   #7
Mr-s413bt's Avatar
Heya Guys.
Cool thanks, I guess i better start playing with compounds soon then!
Hey Bradd and Josh, are you both heading over to SA for the state titles this november??
Glenn
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
