Old 05-02-2014, 12:23 PM   #1
32819toon's Avatar
Default Speed control delay
My son's Hobbywing v2 speed control has a problem. After reverse, there is a slight delay before forward engages. Anyone know why this would be ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 05-02-2014, 01:14 PM   #2
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Often a small delay is meant to not strip gears or burnout motors. From reverse to forward seems odd though. I'd probably check the radio settings or start from scratch by resyncing the ESC to the receiver and resetting it too.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 05-02-2014, 01:25 PM   #3
nrtv20's Avatar
This sounds like the correct answer...
Is it sensorless? maybe you have the direction reversed on the speedo/radio and wires swapped from speedo to motor?
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 05-02-2014, 01:34 PM   #4
There is often a delay in both directions built into an ESC. From reverse to forward especially because that is what most people use to try and get an RC car to pop wheelies which inevitably leads to a stripped gear. Typically from forward to reverse the ESC will go into braking mode before it will go into reverse so you get a delay there as well.
Old 05-02-2014, 01:44 PM   #5
Trader Rating: 27 (100%+)
It's supposed to do that so you don't abruptly go fwd/rev and strip gears.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 05-02-2014, 03:33 PM   #6
32819toon's Avatar
Thanks for the responses. Understand about the stripping of gears, but I've never seen this delay before. It's a sensored set up. I did re-calibrate the esc, but its still the same.
32819toon
Old 05-03-2014, 03:10 PM   #7
We also found the delay with other HW ESCs when large amounts of drag brake and/or after heavy braking. Solution at least for us was to just use forward only and no more delay.
John Wallace2 is offline   Reply With Quote
Old 05-03-2014, 03:33 PM   #8
It'll always be that way.
Old 05-03-2014, 05:56 PM   #9
TB03Racer09's Avatar
most hobbywing esc give you the option to make it go from forward to reverse instantly through programming but this is only used for rock crawling.
TB03Racer09 is offline   Reply With Quote
Old 05-04-2014, 11:44 AM   #10
32819toon's Avatar
Thanks for the help guys. I've had other Hobbywing esc before, including sensorless ones, Speed Passion and Turnigy ones, but never a delay such as this. It does have 10% drag brake, but I've always used that. I'll try no drag brake and see what happens.
32819toon
Old 05-04-2014, 01:54 PM   #11
mkiiina's Avatar
Trader Rating: 69 (100%+)
This is normal functionality. The justock acts the same way but the v3 and v3.1 does not. Tapping the brakes 2x in a row will trigger the delay.
mkiiina is offline   Reply With Quote
